Unprocessed messages is constantly increasing
hi, " unprocessed messages " on my server is constantly increasing. Also, “process buffer” and “output buffer” are always 100%.
My server has 8 cores and 21 gb ram. I write my confic below. Where am I making mistakes?
is_master = true
password_secret =
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 20
#elasticsearch_max_total_connections = 20
# elasticsearch server).
# Default: 2
#elasticsearch_max_total_connections_per_route = 2
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
#elasticsearch_max_retries = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
#elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
# Default: 30s
# Default: false
# Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies:
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
# valid values are "count", "size" and "time", default is "count"
#            This configuration setting is only used on the first start of Graylog. After that,
#            index related settings can be changed in the Graylog web interface on the 'System / Indices' page.
#            Also see http://docs.graylog.org/en/2.3/pages/configuration/index_model.html#index-set-configuration.
rotation_strategy = count
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
#no_retention = false
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
# Default: graylog-internal
# be enabled with care. See also: http://docs.graylog.org/en/2.1/pages/queries.html
allow_highlighting = false
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
# Default: 1h
# Default: 20
# Default: 1h
# Time interval for the job that runs index field type maintenance tasks like cleaning up stale entries. This doesn't
# need to run very often.
# Default: 1h
#index_field_type_periodical_interval = 1h
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# The following settings (outputbuffer_processor_*) configure the thread pools backing each output buffer processor.
# See https://docs.oracle.com/javase/8/docs/api/java/util/concurrent/ThreadPoolExecutor.html for technical details
# When the number of threads is greater than the core (see outputbuffer_processor_threads_core_pool_size),
# this is the maximum time in milliseconds that excess idle threads will wait for new tasks before terminating.
# Default: 5000
# The number of threads to keep in the pool, even if they are idle, unless allowCoreThreadTimeOut is set
# Default: 3
# The maximum number of threads to allow in the pool
# Default: 30
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
# ATTENTION:
# disabled if not set.
# Length of the interval in seconds in which the alert conditions for all streams should be checked
# and alarms are being sent.
#alert_check_interval = 60
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
# '+'-signs in the username or password need to be replaced by '%2B'
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog
# http://api.mongodb.com/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
ully qualified base url to your web interface exactly the same way as it is accessed by your users.
transport_email_web_interface_url = http://192.168.0.44:9000/
/etc/default/graylog-server
> # Path to the java executable.
> JAVA=/usr/bin/java
> # Default Java options for heap and garbage collection.
> GRAYLOG_SERVER_JAVA_OPTS="-Xms1g -Xmx4g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow"
> # Pass some extra args to graylog-server. (i.e. "-d" to enable debug mode)
> GRAYLOG_SERVER_ARGS=""
> # Program that will be used to wrap the graylog-server command. Useful to
> # support programs like authbind.
> GRAYLOG_COMMAND_WRAPPER=""
/etc/default/elasticsearch
> # Elasticsearch
> # Elasticsearch home directory
> #ES_HOME=/usr/share/elasticsearch
> # Elasticsearch Java path
> #JAVA_HOME=
> # Elasticsearch configuration directory
> ES_PATH_CONF=/etc/elasticsearch
> # Elasticsearch PID directory
> #PID_DIR=/var/run/elasticsearch
> # Additional Java OPTS
> #ES_JAVA_OPTS=
> # Configure restart on package upgrade (true, every other setting will lead to not restarting)
> #RESTART_ON_UPGRADE=true
> # Elasticsearch service
> # SysV init.d
> # The number of seconds to wait before checking if Elasticsearch started successfully as a daemon process
> ES_STARTUP_SLEEP_TIME=5
> # System properties
> # Specifies the maximum file descriptor number that can be opened by this process
> # When using Systemd, this setting is ignored and the LimitNOFILE defined in
> # /usr/lib/systemd/system/elasticsearch.service takes precedence
> #MAX_OPEN_FILES=65535
> # The maximum number of bytes of memory that may be locked into RAM
> # Set to "unlimited" if you use the 'bootstrap.memory_lock: true' option
> # in elasticsearch.yml.
> # When using systemd, LimitMEMLOCK must be set in a unit file such as
> # /etc/systemd/system/elasticsearch.service.d/override.conf.
> #MAX_LOCKED_MEMORY=unlimited
> # Maximum number of VMA (Virtual Memory Areas) a process can own
> # When using Systemd, this setting is ignored and the 'vm.max_map_count'
> # property is set at boot time in /usr/lib/sysctl.d/elasticsearch.conf
> #MAX_MAP_COUNT=262144
Read through this thread for some possibilities - in short some people are seeing malformed GROK lock up processing. This may or may not be the issue but it might be a reasonable place to look…
Unfortunately. I couldn’t find a solution. unprocessed messages is now 16.xxx.xxx.xxx :frowning:,
Looks like Elasticsearch isn’t receiving - Anything interesting in the logs on Graylog or in Elasticseatch? Any recent changes? have you restarted graylog or elasticsearch ?
