Topdesk Alarm Callback
@cvtienhoven
Plugin 1.0.10
Topdesk Alarm Callback for Graylog
@cvtienhoven
Topdesk Plugin for Graylog
Required Graylog version: 2.4 and later
This plugin enables you to call the Topdesk API to create incidents.
Installation
Download the plugin and place the .jar file in your Graylog plugin directory. The plugin directory is the plugins/ folder relative from your graylog-server directory by default and can be configured in your graylog.conf file.
Restart graylog-server and you are done.
Use cases
This plugin is useful when you need to create incidents in Topdesk.
Usage
Configure the alarm callback
You can configure an alert condition in Graylog and add the Topdesk Alarm Callback as the Callback Type. In the popup that occurs you can configure the options to send the incident. Not all optional API request fields are implemented, but this should get you going. Also some find and replace in the description makes it possible to define a template and replace the placeholders with a field value for the first message. You can also use some basic HTML tags as described in the Topdesk API for the request field.
Note : Currently an HTTPS connection is established over without verifying certificates. Connection options might be extended in the future.
Getting started
This project is using Maven 3 and requires Java 8 or higher.
- Clone this repository.
- Run
mvn packageto build a JAR file. - Optional: Run
mvn jdeb:jdebandmvn rpm:rpmto create a DEB and RPM package respectively. - Copy generated JAR file in target directory to your Graylog plugin directory.
- Restart the Graylog.
Plugin Release
We are using the maven release plugin:
$ mvn release:prepare
$ mvn release:perform
This sets the version numbers, creates a tag and pushes to GitHub. Travis CI will build the release artifacts and upload to GitHub automatically.
