Twilio
Plugin 1.0.0
Transport that sends alarms via the Twilio SMS API
Twilio SMS Plugin for Graylog
An alarm callback plugin for integrating the Twilio SMS API into Graylog.
Required Graylog version: 2.0.0 and later
Installation
Download the plugin and place the .jar file in your Graylog plugin directory. The plugin directory is the plugins/ folder relative from your graylog-server directory by default and can be configured in your graylog.conf file.
Restart graylog-server and you are done.
Build
This project is using Maven 3 and requires Java 8 or higher.
You can build the plugin (JAR) with mvn package .
DEB and RPM packages can be built with mvn jdeb:jdeb and mvn rpm:rpm respectively.
Plugin Release
We are using the maven release plugin:
$ mvn release:prepare
$ mvn release:perform
This sets the version numbers, creates a tag and pushes to GitHub. Travis CI will build the release artifacts and upload to GitHub automatically.
