I am trying to use a pipeline to parse out the UNIX timestamp from a Meraki MX firewall flow log. I almost have it, but the to_long function is converting the value to “0”.
OS Information: Ubuntu 22.04
Package Version: 5.0.7-1
PIPELINE RULE:
rule “UNIX timestamp”
has_field(“message”) && (contains(to_string($message.message),“flows”)||contains(to_string($message.message),“firewall”))
// UNIX epoch
let epoch_time = grok(pattern:“%{UNIXTIME}”,value:to_string($message.message)).NUMBER;
debug(epoch_time);
let ts_seconds_lng = to_long(epoch_time);
debug(ts_seconds_lng);
let new_ts = parse_unix_milliseconds(ts_seconds_lng,“America/Chicago”);
set_field(“timestamp”, new_ts);
DEBUG OUTPUT:
2023-05-17T15:59:51.554-05:00 INFO [Function] PIPELINE DEBUG: 1684341977.212982350
2023-05-17T15:59:51.555-05:00 INFO [Function] PIPELINE DEBUG: 0
I have tried different ways to extract the time stamp as well as converting to double then long, but that did not work either.
Explain why the return value is 0 when converting to long.
// UNIX epoch
let epoch_time = grok(pattern:“%{UNIXTIME}”,value:to_string($message.message)).ts;
let ts_seconds_lng = to_long(epoch_time) * 1000;
Drew, I really appreciate your assistance. I did not realize that long types could not have decimals, which seems to be the issue. I was able to manually extract the data to get what I wanted using the code below:
Pipeline Rule:
rule “Meraki UNIX TS Test”
let epoch_time_ts = to_string(grok(pattern:“%{MERAKI_MX_UNIXTIME_TEST}”,value:to_string($message.message)).ts);
let epoch_time_ms = to_string(grok(pattern:“%{MERAKI_MX_UNIXTIME_TEST}”,value:to_string($message.message)).ms);
let epoch_time_concat = concat(epoch_time_ts,substring(epoch_time_ms,0,3));
let ts_seconds = to_long(epoch_time_concat);
let new_ts = parse_unix_milliseconds(ts_seconds,“America/Chicago”);
