Timestamp widget
I have a problem with the date on widgets. In the Message Table widget I have the good date with timezone. for example : 2020-03-02 09:57:58 +01:00. But in Message count widget the date is without the timezone. 2020-03-02 08:57:58.
Someone have an idea how to fix it ?
Thanks,
he @LensHunnel
what Graylog version are we talking about?
hi @jan ,
I am on graylog 3.2.1
@LensHunnel can you make a screenshot? I do not understand what you mean with Message Count widget.
The message count widget does not have a timestamp.
The number widget where you can have a max(timestamp) series, presents to me the
timestamp with the the correct timezone :confused:
Hello @konrad ,
As you see in the image below, on the first widget the last time is around 14h28 but on the second widget “All Messages” the last message is at 15h28…Thanks
