Timestamp warning when sending GELF from Rsyslog
Hi, all!
I’m trying to send GELF messages from rsyslog (version 8.16.0-1ubuntu3 on Ubuntu 16.04.4 LTS) to Graylog (version 2.3.1-1) with this template:
template(name="gelf_docker" type="list") {
    constant(value="{\"version\":\"1.1\",")
    constant(value="\"host\":\"")
    property(name="hostname")
    constant(value="\",\"short_message\":\"")
    property(name="msg" format="json")
    constant(value="\",\"timestamp\":\"")
    property(name="timegenerated" dateformat="unixtimestamp")
    constant(value="\",\"_application_name\":\"kubernetes\",")
    constant(value="\"_full_container_name\":\"")
    property(name="$.full_container_name")
    constant(value="\",\"_container_name\":\"")
    property(name="$.container_name")
    constant(value="\",\"_container_id\":\"")
    property(name="$.container_id")
    constant(value="\",\"_pod_name\":\"")
    property(name="$.io_kubernetes_pod_name")
    constant(value="\",\"_pod_namespace\":\"")
    property(name="$.io_kubernetes_pod_namespace")
    constant(value="\"}\n")
But, I’m getting a lot of warnings on Graylog server log like this:
2018-07-29T00:37:21.389+03:00 WARN  [GelfCodec] GELF message <68bb24af-92ae-11e8-9967-005056b51dfc> (received from <:53874>) has invalid "timestamp": 1532813840  (type: STRING)
Rsyslog template was made according to this manual: Gelf forwarding
the timestamp need to be ISO8601 not Unix.
Hi!
According to this doc: Rsyslog property replacer rsyslog doesn’t have ISO8601 option for data format, but has rfc3339 option. I’ve tried to change line with dateformat to:
property(name="timegenerated" dateformat="rfc3339")
But it didn’t help, now i have such warnings in Graylog server log:
2018-08-10T11:01:56.324+03:00 WARN [GelfCodec] GELF message <a67d9428-9c73-11e8-9967-005056b51dfc> (received from <:43631>) has invalid "timestamp": 2018-08-10T11:01:55.979122+03:00 (type: STRING)
my bad - according to the spec unixtimestamp should work.
http://docs.graylog.org/en/2.4/pages/gelf.html#gelf-payload-specification
This might be something with your Graylog Version (Current stable 2.4.6) but not sure. About.
@pvlltvk did you get anywhere with this particular WARN message? I’m seeing the exact same thing (lots of identical warnings) in v2.4.6. Are you running 2.4.6 as well?
2018-08-23T14:51:21.478-05:00 WARN  [GelfCodec] GELF message <e8ab8b50-a70d-11e8-8c3f-0050569991aa> (received from <10.10.10.22:52047>) has invalid "timestamp": 1535053881.403  (type: STRING)
2018-08-23T14:51:24.560-05:00 WARN  [GelfCodec] GELF message <ea81f900-a70d-11e8-8c3f-0050569991aa> (received from <10.10.10.22:52047>) has invalid "timestamp": 1535053884.535  (type: STRING)
2018-08-23T14:51:24.744-05:00 WARN  [GelfCodec] GELF message <ea9de570-a70d-11e8-8c3f-0050569991aa> (received from <10.10.10.22:52047>) has invalid "timestamp": 1535053884.72  (type: STRING)
2018-08-23T14:51:24.801-05:00 WARN  [GelfCodec] GELF message <eaa69800-a70d-11e8-8c3f-0050569991aa> (received from <10.10.10.22:52047>) has invalid "timestamp": 1535053884.776  (type: STRING)
2018-08-23T14:51:24.802-05:00 WARN  [GelfCodec] GELF message <eaa6bf11-a70d-11e8-8c3f-0050569991aa> (received from <10.10.10.22:52047>) has invalid "timestamp": 1535053884.776  (type: STRING)
@MrMike
you could open a bug issue for that: https://github.com/Graylog2/graylog2-server/issues
It looks like the timestamp is not allowed to contain microseconds what is causing the issue.
No, i’m still on 2.3.1, but now i’m thinking, that it’s not version of specific bug :smiley:
By the way, I’ve tried various timestamps: unixtime (with or without microseconds), rfc3389, but warning messages still remains.
