Timestamp issue/question
I have the same issue as described in this post:
In System/Overview, all 3 times are the same and correct.
My concern is that when I do a search for any new (in the last 5 minutes), nothing shows up because of this time discrepancy. I have to change it for “in the last 8 hours” in order to see any data.
I do not understand the above linked post’s comments, so I don’t know if a fix was mentioned (timestamp conversion) or not.
I am not sure if I have the same issue:
Graylog 3.0.2+1686930, codename Space Moose
Host OS: Ubuntu 18.04.3 LTS
Host: 2020-02-15 11:52:05 +08:00
Time configuration
User ******: 2020-02-15 11:52:05 +08:00
Your web browser: 2020-02-15 11:52:05 +08:00
Graylog server: 2020-02-15 11:52:29 +08:00
root_timezone = UTC
The syslog with timestamp with UTC got transformed to UTC-8 as raw data. It’s doing well if your syslog timestamp is in UTC+8, which is not the standard as we wish.
How do I stop the transformation for particular syslog if there’s still other raw data need to be transformed?
update: the timestamp is minus 8 hours behind and only the full_message shows the correct one.
the question is:
  • does that timestamp include a timezone?
If the timestamp did not include timezone information, Graylog works with that timestamp as it is UTC.
