TCP Messages not showing on GL despite connection is OK
Messages from some servers using the same rsyslog configuration files are not being shown on GL.
  • OS Information: Ubuntu 20.04 LTS
  • Package Version: GL 4.3.7 + OpenSearch 1.3.3
Input in use for the VMs:
It works and receives messages.
General behavior:
$ cat /etc/rsyslog.d/graylog.conf
*.* @@graylog-lb:1514;RSYSLOG_SyslogProtocol23Format
And for nginx in particular:
$ cat /etc/rsyslog.d/nginx.conf
# Ansible Managed
input(type="imfile"
      File="/var/log/nginx/*.log"
      Tag="nginx"
      Severity="info"
      Facility="local1")
local1.* @@graylog-lb:1514;RSYSLOG_SyslogProtocol23Format
The imfile module is enabled in rsyslog:
$ grep imfile /etc/rsyslog.conf
module(load="imfile" PollingInterval="10")
…and the service was restarted by Ansible after applying the changes.
Before posting this message, I checked in the forums and found this related issue:
The time-stamp don’t seem to be an issue in my case:
After checking that the time was not the problem, I left this running on both GL nodes:
tcpdump -vnX src 10.10.10.51 -w 20220929.pcap
On one of the affected GL clients I created a test message:
root@gl-client:~# logger -t MY_TAG "This is another a test message for you"
I could see how the tcpdump on the gl-node-2 was more active, so I checked:
root@gl-node-2:~# tcpdump -qns 0 -A -r 20220929.pcap  | grep MY_TAG
reading from file 20220929.pcap, link-type EN10MB (Ethernet)
1..[....<13>1 2022-09-29T09:31:46.423600+00:00 gl-client MY_TAG - - -  This is another a test message for you
root@gl-node-2:~#
Messages are, indeed, being delivered from the clients to the GL cluster.
Other VMs with the same rsyslog config are shown on the GL GUI when someone searches for them, but not this set of VMs. Am I overlooking the obvious??
TIA for your help!
Hey @m_mlk
Correct me if I’m wrong. the connections Between client and GL are fine , You identified that messages are showing up to Graylog Server, either through tcpdump or other means, but there are no message on the GUI.
I’m assume you check Elasticsearch/Opensearch is running correct?
EDIT: Another thought, have you tried a different input for testing, perhaps Raw Plaintext input instead of GELF?
Hi @gsmith
GL is working fine. Let’s say we had 500 servers sending stuff to the GL cluster in the past using GELF/tcp. All those show up flawlessly. I added a new set of VMs (ca. 20 items) and those are not being shown at all.
I have run searches for the source, host_name, applicaton_name, etc etc. Nothing comes back…
As I said, the configuration is the same on all VMs… O_o
Thanks!
Replying to myself…
I went over the rsyslog configuration of the working nodes and compared it to the one on the ones where GL was failing to show information from…
It seems like there was some hidden character (md5sum FTW!!!); I fixed the template again and all VMs are now shown on GL as expected.
Thanks all @gsmith for your assistance anyway!
Cheers
