Not receiving TCP messages
Input Syslog TCP on port 1514 not receiving messages on graylog, but I can see traffic when I run “sudo tcpdump -i any -v port 1514”
  • OS Information: Ubuntu 20.04
  • Package Version:graylog v. 4.2.9
    All standard. Elastic search, mongo, graylog, etc. all services running with no errors.
-re-creating the input
-sending logs from more devices
Hi all. New to graylog and the community, please help me troubleshot why I am not receiving TCP logs in port 1514 from Input Syslog TCP (Syslog UDP is fine, I am receiving messages in graylog platform).
Hello && Welcome @holiveir
I might be able to help. This could be a couple of different solution.
We would need to know the following:
  • Show the configuration on the input used.
  • Date/Time are correct. Located under System/Overview → Time configuration
  • What do you see in the log files that may pertain to this issue (i.e. Elasticsearch, MongoDb, Graylog, etc…)
  • Have you tried a different type of input, for example Syslog UDP?
  • Is this a fresh install?
  • Are there any extractors or pipeline running on this INPUT?
Hi @gsmith, it was the Date/Time that was not sync between user, system and web browser. I receive logs normally now. Thanks for your input, it helped me to do some more specific research and troubleshooting.
It happens, glad I could help. If you could mark this as resolved for future searches that would be great.
