System error and search error
This is the system error
Input 59a08d84bf9d2a06160d8e8f has failed to start on node ffabfc04-56cd-4ef3-acc9-d25048eecebc for this reason: »Address already in use.«. This means that you are unable to receive any messages from this input. This is mostly an indication for a misconfiguration or an error. You can click here to solve this.
This is the search error
These two errors are most likely not related.
For the first one (Address already in use), make sure that your inputs are using a unique port and that no two inputs use the same port.
For the second, check the logs of your Graylog and Elasticsearch nodes.
http://docs.graylog.org/en/2.3/pages/configuration/file_location.html
