ElasticSearch Error on Graylog
Hi Kindly assist me with the Elasticsearch error that I am getting:
Error Message:
Unable to perform search query
Details:
Search Status Code:
500
Search Response:
Cannot GET http://192.168.100.20:9000/api/search/universal//relative?query=gl2_source_input%3A5ac5d6b2&range=0&limit=150&sort=timestamp%3Ades(500)
Regards,
Kindly share the complete logs of your Graylog and Elasticsearch nodes.
:arrow_right: http://docs.graylog.org/en/2.4/pages/configuration/file_location.html
Hi Jochen,
Check blow:
[2018-04-05T07:21:00,081][INFO ][o.e.n.Node ] [] initializing …
[2018-04-05T07:21:00,459][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] using [1] data paths, mounts [[/ (/dev/mapper/graylog–vg-root)]], net usable_space [11.2gb], net total_space [14.9gb], spins? [possibly], types [ext4]
[2018-04-05T07:21:00,460][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] heap size [2.3gb], compressed ordinary object pointers [true]
[2018-04-05T07:21:00,461][INFO ][o.e.n.Node ] node name [yEpjBc2] derived from node ID [yEpjBc2qTNm3OuYlP5myjQ]; set [node.name] to override
[2018-04-05T07:21:00,462][INFO ][o.e.n.Node ] version[5.6.3], pid[1229], build[1a2f265/2017-10-06T20:33:39.012Z], OS[Linux/4.4.0-116-generic/amd64], JVM[Oracle Corporation/Java HotSpot™ 64-Bit Server VM/1.8.0_161/25.161-b12]
[2018-04-05T07:21:00,462][INFO ][o.e.n.Node ] JVM arguments [-Xms2371m, -Xmx2371m, -Djava.net.preferIPv4Stack=true, -Dlog4j2.disable.jmx=true, -XX:+UseParNewGC, -XX:+UseConcMarkSweepGC, -XX:+CMSParallelRemarkEnabled, -XX:SurvivorRatio=8, -XX:MaxTenuringThreshold=1, -XX:CMSInitiatingOccupancyFraction=75, -XX:+UseCMSInitiatingOccupancyOnly, -XX:+HeapDumpOnOutOfMemoryError, -Des.path.home=/opt/graylog/elasticsearch]
[2018-04-05T07:21:02,424][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [aggs-matrix-stats]
[2018-04-05T07:21:02,425][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [ingest-common]
[2018-04-05T07:21:02,426][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-expression]
[2018-04-05T07:21:02,428][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-groovy]
[2018-04-05T07:21:02,428][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-mustache]
[2018-04-05T07:21:02,428][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-painless]
[2018-04-05T07:21:02,429][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [parent-join]
[2018-04-05T07:21:02,429][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [percolator]
[2018-04-05T07:21:02,430][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [reindex]
[2018-04-05T07:21:02,430][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty3]
[2018-04-05T07:21:02,431][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty4]
[2018-04-05T07:21:02,432][INFO ][o.e.p.PluginsService ] [yEpjBc2] no plugins loaded
[2018-04-05T07:21:07,769][INFO ][o.e.n.Node ] [] initializing …
[2018-04-05T07:21:07,989][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] using [1] data paths, mounts [[/ (/dev/mapper/graylog–vg-root)]], net usable_space [11.2gb], net total_space [14.9gb], spins? [possibly], types [ext4]
[2018-04-05T07:21:07,990][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] heap size [2.3gb], compressed ordinary object pointers [true]
[2018-04-05T07:21:08,004][INFO ][o.e.n.Node ] node name [yEpjBc2] derived from node ID [yEpjBc2qTNm3OuYlP5myjQ]; set [node.name] to override
[2018-04-05T07:21:08,004][INFO ][o.e.n.Node ] version[5.6.3], pid[1431], build[1a2f265/2017-10-06T20:33:39.012Z], OS[Linux/4.4.0-116-generic/amd64], JVM[Oracle Corporation/Java HotSpot™ 64-Bit Server VM/1.8.0_161/25.161-b12]
[2018-04-05T07:21:08,005][INFO ][o.e.n.Node ] JVM arguments [-Xms2371m, -Xmx2371m, -Djava.net.preferIPv4Stack=true, -Dlog4j2.disable.jmx=true, -XX:+UseParNewGC, -XX:+UseConcMarkSweepGC, -XX:+CMSParallelRemarkEnabled, -XX:SurvivorRatio=8, -XX:MaxTenuringThreshold=1, -XX:CMSInitiatingOccupancyFraction=75, -XX:+UseCMSInitiatingOccupancyOnly, -XX:+HeapDumpOnOutOfMemoryError, -Des.path.home=/opt/graylog/elasticsearch]
[2018-04-05T07:21:09,823][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [aggs-matrix-stats]
[2018-04-05T07:21:09,826][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [ingest-common]
[2018-04-05T07:21:09,827][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-expression]
[2018-04-05T07:21:09,827][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-groovy]
[2018-04-05T07:21:09,828][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-mustache]
[2018-04-05T07:21:09,828][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-painless]
[2018-04-05T07:21:09,828][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [parent-join]
[2018-04-05T07:21:09,828][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [percolator]
[2018-04-05T07:21:09,829][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [reindex]
[2018-04-05T07:21:09,829][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty3]
[2018-04-05T07:21:09,829][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty4]
[2018-04-05T07:21:09,830][INFO ][o.e.p.PluginsService ] [yEpjBc2] no plugins loaded
[2018-04-05T07:21:13,155][INFO ][o.e.d.DiscoveryModule ] [yEpjBc2] using discovery type [zen]
[2018-04-05T07:21:15,433][INFO ][o.e.n.Node ] initialized
[2018-04-05T07:21:15,434][INFO ][o.e.n.Node ] [yEpjBc2] starting …
[2018-04-05T07:21:15,525][INFO ][i.n.u.i.PlatformDependent] Your platform does not provide complete low-level API for accessing direct buffers reliably. Unless explicitly requested, heap buffer will always be preferred to avoid potential system instability.
[2018-04-05T07:21:15,759][INFO ][o.e.t.TransportService ] [yEpjBc2] publish_address {192.168.100.39:9300}, bound_addresses {192.168.100.39:9300}
[2018-04-05T07:21:15,788][INFO ][o.e.b.BootstrapChecks ] [yEpjBc2] bound or publishing to a non-loopback or non-link-local address, enforcing bootstrap checks
[2018-04-05T07:21:25,899][INFO ][o.e.c.s.ClusterService ] [yEpjBc2] new_master {yEpjBc2}{yEpjBc2qTNm3OuYlP5myjQ}{MTY52NvGStiAEYZxMLGyUA}{192.168.100.39}{192.168.100.39:9300}, reason: zen-disco-elected-as-master ([0] nodes joined)
[2018-04-05T07:21:26,040][INFO ][o.e.h.n.Netty4HttpServerTransport] [yEpjBc2] publish_address {192.168.100.39:9200}, bound_addresses {192.168.100.39:9200}
[2018-04-05T07:21:26,041][INFO ][o.e.n.Node ] [yEpjBc2] started
[2018-04-05T07:21:26,093][INFO ][o.e.g.GatewayService ] [yEpjBc2] recovered [0] indices into cluster_state
[2018-04-05T07:21:35,248][INFO ][o.e.c.m.MetaDataCreateIndexService] [yEpjBc2] [graylog_0] creating index, cause [api], templates [graylog-internal], shards [4]/[1], mappings [message]
[2018-04-05T07:21:38,812][INFO ][o.e.c.m.MetaDataMappingService] [yEpjBc2] [graylog_0/GP7VM0AJTqGCQLh3YXOTtQ] update_mapping [message]
[2018-04-05T07:29:14,256][INFO ][o.e.n.Node ] [yEpjBc2] stopping …
[2018-04-05T07:31:39,309][INFO ][o.e.n.Node ] [] initializing …
[2018-04-05T07:31:39,623][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] using [1] data paths, mounts [[/ (/dev/mapper/graylog–vg-root)]], net usable_space [11.3gb], net total_space [14.9gb], spins? [possibly], types [ext4]
[2018-04-05T07:31:39,623][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] heap size [2.3gb], compressed ordinary object pointers [true]
[2018-04-05T07:31:39,671][INFO ][o.e.n.Node ] node name [yEpjBc2] derived from node ID [yEpjBc2qTNm3OuYlP5myjQ]; set [node.name] to override
[2018-04-05T07:31:39,672][INFO ][o.e.n.Node ] version[5.6.3], pid[778], build[1a2f265/2017-10-06T20:33:39.012Z], OS[Linux/4.4.0-116-generic/amd64], JVM[Oracle Corporation/Java HotSpot™ 64-Bit Server VM/1.8.0_161/25.161-b12]
[2018-04-05T07:31:39,672][INFO ][o.e.n.Node ] JVM arguments [-Xms2371m, -Xmx2371m, -Djava.net.preferIPv4Stack=true, -Dlog4j2.disable.jmx=true, -XX:+UseParNewGC, -XX:+UseConcMarkSweepGC, -XX:+CMSParallelRemarkEnabled, -XX:SurvivorRatio=8, -XX:MaxTenuringThreshold=1, -XX:CMSInitiatingOccupancyFraction=75, -XX:+UseCMSInitiatingOccupancyOnly, -XX:+HeapDumpOnOutOfMemoryError, -Des.path.home=/opt/graylog/elasticsearch]
[2018-04-05T07:31:41,383][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [aggs-matrix-stats]
[2018-04-05T07:31:41,383][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [ingest-common]
[2018-04-05T07:31:41,399][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-expression]
[2018-04-05T07:31:41,409][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-groovy]
[2018-04-05T07:31:41,410][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-mustache]
[2018-04-05T07:31:41,410][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-painless]
[2018-04-05T07:31:41,410][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [parent-join]
[2018-04-05T07:31:41,411][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [percolator]
[2018-04-05T07:31:41,411][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [reindex]
[2018-04-05T07:31:41,412][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty3]
[2018-04-05T07:31:41,413][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty4]
[2018-04-05T07:31:41,414][INFO ][o.e.p.PluginsService ] [yEpjBc2] no plugins loaded
[2018-04-05T07:31:45,394][INFO ][o.e.d.DiscoveryModule ] [yEpjBc2] using discovery type [zen]
[2018-04-05T07:31:46,610][INFO ][o.e.n.Node ] initialized
[2018-04-05T07:31:46,611][INFO ][o.e.n.Node ] [yEpjBc2] starting …
[2018-04-05T07:31:46,703][INFO ][i.n.u.i.PlatformDependent] Your platform does not provide complete low-level API for accessing direct buffers reliably. Unless explicitly requested, heap buffer will always be preferred to avoid potential system instability.
[2018-04-05T07:31:46,827][WARN ][i.n.u.i.MacAddressUtil ] Failed to find a usable hardware address from the network interfaces; using random bytes: 72:39:44:30:2d:e3:77:4d
[2018-04-05T07:31:47,171][ERROR][o.e.b.Bootstrap ] [yEpjBc2] Exception
org.elasticsearch.transport.BindTransportException: Failed to bind to [9300-9400]
at org.elasticsearch.transport.TcpTransport.bindToPort(TcpTransport.java:780) ~[elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.transport.TcpTransport.bindServer(TcpTransport.java:745) ~[elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.transport.netty4.Netty4Transport.doStart(Netty4Transport.java:174) ~[?:?]
at org.elasticsearch.common.component.AbstractLifecycleComponent.start(AbstractLifecycleComponent.java:69) ~[elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.transport.TransportService.doStart(TransportService.java:209) ~[elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.node.Node.start(Node.java:694) ~[elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.bootstrap.Bootstrap.start(Bootstrap.java:278) ~[elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:351) [elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:132) [elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.bootstrap.Elasticsearch.execute(Elasticsearch.java:123) [elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:70) [elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:134) [elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.cli.Command.main(Command.java:90) [elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:91) [elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:84) [elasticsearch-5.6.3.jar:5.6.3]
Caused by: java.net.BindException: Cannot assign requested address
at sun.nio.ch.Net.bind0(Native Method) ~[?:?]
at sun.nio.ch.Net.bind(Net.java:433) ~[?:?]
at sun.nio.ch.Net.bind(Net.java:425) ~[?:?]
at sun.nio.ch.ServerSocketChannelImpl.bind(ServerSocketChannelImpl.java:223) ~[?:?]
at io.netty.channel.socket.nio.NioServerSocketChannel.doBind(NioServerSocketChannel.java:128) ~[?:?]
at io.netty.channel.AbstractChannel$AbstractUnsafe.bind(AbstractChannel.java:554) ~[?:?]
at io.netty.channel.DefaultChannelPipeline$HeadContext.bind(DefaultChannelPipeline.java:1258) ~[?:?]
at io.netty.channel.AbstractChannelHandlerContext.invokeBind(AbstractChannelHandlerContext.java:501) ~[?:?]
at io.netty.channel.AbstractChannelHandlerContext.bind(AbstractChannelHandlerContext.java:486) ~[?:?]
at io.netty.channel.DefaultChannelPipeline.bind(DefaultChannelPipeline.java:980) ~[?:?]
at io.netty.channel.AbstractChannel.bind(AbstractChannel.java:250) ~[?:?]
at io.netty.bootstrap.AbstractBootstrap$2.run(AbstractBootstrap.java:365) ~[?:?]
at io.netty.util.concurrent.AbstractEventExecutor.safeExecute(AbstractEventExecutor.java:163) ~[?:?]
at io.netty.util.concurrent.SingleThreadEventExecutor.runAllTasks(SingleThreadEventExecutor.java:403) ~[?:?]
at io.netty.channel.nio.NioEventLoop.run(NioEventLoop.java:462) ~[?:?]
at io.netty.util.concurrent.SingleThreadEventExecutor$5.run(SingleThreadEventExecutor.java:858) ~[?:?]
at java.lang.Thread.run(Thread.java:748) ~[?:1.8.0_161]
[2018-04-05T07:31:47,187][WARN ][o.e.b.ElasticsearchUncaughtExceptionHandler] [] uncaught exception in thread [main]
org.elasticsearch.bootstrap.StartupException: BindTransportException[Failed to bind to [9300-9400]]; nested: BindException[Cannot assign requested address];
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:136) ~[elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.bootstrap.Elasticsearch.execute(Elasticsearch.java:123) ~[elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.cli.EnvironmentAwareCommand.execute(EnvironmentAwareCommand.java:70) ~[elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.cli.Command.mainWithoutErrorHandling(Command.java:134) ~[elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.cli.Command.main(Command.java:90) ~[elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:91) ~[elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.bootstrap.Elasticsearch.main(Elasticsearch.java:84) ~[elasticsearch-5.6.3.jar:5.6.3]
Caused by: org.elasticsearch.transport.BindTransportException: Failed to bind to [9300-9400]
at org.elasticsearch.bootstrap.Bootstrap.init(Bootstrap.java:351) ~[elasticsearch-5.6.3.jar:5.6.3]
at org.elasticsearch.bootstrap.Elasticsearch.init(Elasticsearch.java:132) ~[elasticsearch-5.6.3.jar:5.6.3]
… 6 more
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_161]
[2018-04-05T07:31:47,721][INFO ][o.e.n.Node ] [yEpjBc2] stopping …
[2018-04-05T07:31:49,855][INFO ][o.e.n.Node ] [] initializing …
[2018-04-05T07:31:50,074][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] using [1] data paths, mounts [[/ (/dev/mapper/graylog–vg-root)]], net usable_space [11.3gb], net total_space [14.9gb], spins? [possibly], types [ext4]
[2018-04-05T07:31:50,076][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] heap size [2.3gb], compressed ordinary object pointers [true]
[2018-04-05T07:31:50,104][INFO ][o.e.n.Node ] node name [yEpjBc2] derived from node ID [yEpjBc2qTNm3OuYlP5myjQ]; set [node.name] to override
[2018-04-05T07:31:50,104][INFO ][o.e.n.Node ] version[5.6.3], pid[1041], build[1a2f265/2017-10-06T20:33:39.012Z], OS[Linux/4.4.0-116-generic/amd64], JVM[Oracle Corporation/Java HotSpot™ 64-Bit Server VM/1.8.0_161/25.161-b12]
[2018-04-05T07:31:50,105][INFO ][o.e.n.Node ] JVM arguments [-Xms2371m, -Xmx2371m, -Djava.net.preferIPv4Stack=true, -Dlog4j2.disable.jmx=true, -XX:+UseParNewGC, -XX:+UseConcMarkSweepGC, -XX:+CMSParallelRemarkEnabled, -XX:SurvivorRatio=8, -XX:MaxTenuringThreshold=1, -XX:CMSInitiatingOccupancyFraction=75, -XX:+UseCMSInitiatingOccupancyOnly, -XX:+HeapDumpOnOutOfMemoryError, -Des.path.home=/opt/graylog/elasticsearch]
[2018-04-05T07:31:51,744][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [aggs-matrix-stats]
[2018-04-05T07:31:51,744][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [ingest-common]
[2018-04-05T07:31:51,745][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-expression]
[2018-04-05T07:31:51,745][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-groovy]
[2018-04-05T07:31:51,745][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-mustache]
[2018-04-05T07:31:51,745][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-painless]
[2018-04-05T07:31:51,746][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [parent-join]
[2018-04-05T07:31:51,753][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [percolator]
[2018-04-05T07:31:51,754][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [reindex]
[2018-04-05T07:31:51,755][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty3]
[2018-04-05T07:31:51,755][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty4]
[2018-04-05T07:31:51,756][INFO ][o.e.p.PluginsService ] [yEpjBc2] no plugins loaded
[2018-04-05T07:31:55,013][INFO ][o.e.d.DiscoveryModule ] [yEpjBc2] using discovery type [zen]
[2018-04-05T07:31:55,942][INFO ][o.e.n.Node ] initialized
[2018-04-05T07:31:55,942][INFO ][o.e.n.Node ] [yEpjBc2] starting …
[2018-04-05T07:31:56,012][INFO ][i.n.u.i.PlatformDependent] Your platform does not provide complete low-level API for accessing direct buffers reliably. Unless explicitly requested, heap buffer will always be preferred to avoid potential system instability.
[2018-04-05T07:31:56,119][WARN ][i.n.u.i.MacAddressUtil ] Failed to find a usable hardware address from the network interfaces; using random bytes: 35:c9:58:a5:4f:37:75:da
[2018-04-05T07:31:56,457][ERROR][o.e.b.Bootstrap ] [yEpjBc2] Exception
[2018-04-05T07:31:56,485][WARN ][o.e.b.ElasticsearchUncaughtExceptionHandler] [] uncaught exception in thread [main]
… 6 more
[2018-04-05T07:31:57,036][INFO ][o.e.n.Node ] [yEpjBc2] stopping …
[2018-04-05T07:31:58,771][INFO ][o.e.n.Node ] [] initializing …
[2018-04-05T07:31:58,953][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] using [1] data paths, mounts [[/ (/dev/mapper/graylog–vg-root)]], net usable_space [11.3gb], net total_space [14.9gb], spins? [possibly], types [ext4]
[2018-04-05T07:31:58,954][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] heap size [2.3gb], compressed ordinary object pointers [true]
[2018-04-05T07:31:58,970][INFO ][o.e.n.Node ] node name [yEpjBc2] derived from node ID [yEpjBc2qTNm3OuYlP5myjQ]; set [node.name] to override
[2018-04-05T07:31:58,971][INFO ][o.e.n.Node ] version[5.6.3], pid[1226], build[1a2f265/2017-10-06T20:33:39.012Z], OS[Linux/4.4.0-116-generic/amd64], JVM[Oracle Corporation/Java HotSpot™ 64-Bit Server VM/1.8.0_161/25.161-b12]
[2018-04-05T07:31:58,971][INFO ][o.e.n.Node ] JVM arguments [-Xms2371m, -Xmx2371m, -Djava.net.preferIPv4Stack=true, -Dlog4j2.disable.jmx=true, -XX:+UseParNewGC, -XX:+UseConcMarkSweepGC, -XX:+CMSParallelRemarkEnabled, -XX:SurvivorRatio=8, -XX:MaxTenuringThreshold=1, -XX:CMSInitiatingOccupancyFraction=75, -XX:+UseCMSInitiatingOccupancyOnly, -XX:+HeapDumpOnOutOfMemoryError, -Des.path.home=/opt/graylog/elasticsearch]
[2018-04-05T07:32:00,598][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [aggs-matrix-stats]
[2018-04-05T07:32:00,599][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [ingest-common]
[2018-04-05T07:32:00,599][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-expression]
[2018-04-05T07:32:00,599][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-groovy]
[2018-04-05T07:32:00,599][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-mustache]
[2018-04-05T07:32:00,599][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-painless]
[2018-04-05T07:32:00,605][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [parent-join]
[2018-04-05T07:32:00,605][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [percolator]
[2018-04-05T07:32:00,605][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [reindex]
[2018-04-05T07:32:00,606][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty3]
[2018-04-05T07:32:00,606][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty4]
[2018-04-05T07:32:00,606][INFO ][o.e.p.PluginsService ] [yEpjBc2] no plugins loaded
[2018-04-05T07:32:03,821][INFO ][o.e.d.DiscoveryModule ] [yEpjBc2] using discovery type [zen]
[2018-04-05T07:32:04,888][INFO ][o.e.n.Node ] initialized
[2018-04-05T07:32:04,888][INFO ][o.e.n.Node ] [yEpjBc2] starting …
[2018-04-05T07:32:04,988][INFO ][i.n.u.i.PlatformDependent] Your platform does not provide complete low-level API for accessing direct buffers reliably. Unless explicitly requested, heap buffer will always be preferred to avoid potential system instability.
[2018-04-05T07:32:05,111][WARN ][i.n.u.i.MacAddressUtil ] Failed to find a usable hardware address from the network interfaces; using random bytes: 41:f1:78:c5:48:da:ee:75
[2018-04-05T07:32:05,516][ERROR][o.e.b.Bootstrap ] [yEpjBc2] Exception
[2018-04-05T07:32:05,538][WARN ][o.e.b.ElasticsearchUncaughtExceptionHandler] [] uncaught exception in thread [main]
… 6 more
[2018-04-05T07:32:36,967][INFO ][o.e.n.Node ] [yEpjBc2] stopping …
[2018-04-05T07:32:38,152][INFO ][o.e.n.Node ] [] initializing …
[2018-04-05T07:32:38,299][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] using [1] data paths, mounts [[/ (/dev/mapper/graylog–vg-root)]], net usable_space [11.3gb], net total_space [14.9gb], spins? [possibly], types [ext4]
[2018-04-05T07:32:38,300][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] heap size [2.3gb], compressed ordinary object pointers [true]
[2018-04-05T07:32:38,313][INFO ][o.e.n.Node ] node name [yEpjBc2] derived from node ID [yEpjBc2qTNm3OuYlP5myjQ]; set [node.name] to override
[2018-04-05T07:32:38,314][INFO ][o.e.n.Node ] version[5.6.3], pid[1630], build[1a2f265/2017-10-06T20:33:39.012Z], OS[Linux/4.4.0-116-generic/amd64], JVM[Oracle Corporation/Java HotSpot™ 64-Bit Server VM/1.8.0_161/25.161-b12]
[2018-04-05T07:32:38,314][INFO ][o.e.n.Node ] JVM arguments [-Xms2371m, -Xmx2371m, -Djava.net.preferIPv4Stack=true, -Dlog4j2.disable.jmx=true, -XX:+UseParNewGC, -XX:+UseConcMarkSweepGC, -XX:+CMSParallelRemarkEnabled, -XX:SurvivorRatio=8, -XX:MaxTenuringThreshold=1, -XX:CMSInitiatingOccupancyFraction=75, -XX:+UseCMSInitiatingOccupancyOnly, -XX:+HeapDumpOnOutOfMemoryError, -Des.path.home=/opt/graylog/elasticsearch]
[2018-04-05T07:32:39,173][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [aggs-matrix-stats]
[2018-04-05T07:32:39,173][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [ingest-common]
[2018-04-05T07:32:39,173][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-expression]
[2018-04-05T07:32:39,173][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-groovy]
[2018-04-05T07:32:39,174][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-mustache]
[2018-04-05T07:32:39,174][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-painless]
[2018-04-05T07:32:39,174][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [parent-join]
[2018-04-05T07:32:39,174][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [percolator]
[2018-04-05T07:32:39,174][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [reindex]
[2018-04-05T07:32:39,174][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty3]
[2018-04-05T07:32:39,174][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty4]
[2018-04-05T07:32:39,175][INFO ][o.e.p.PluginsService ] [yEpjBc2] no plugins loaded
[2018-04-05T07:32:41,012][INFO ][o.e.d.DiscoveryModule ] [yEpjBc2] using discovery type [zen]
[2018-04-05T07:32:41,465][INFO ][o.e.n.Node ] initialized
[2018-04-05T07:32:41,465][INFO ][o.e.n.Node ] [yEpjBc2] starting …
[2018-04-05T07:32:41,495][INFO ][i.n.u.i.PlatformDependent] Your platform does not provide complete low-level API for accessing direct buffers reliably. Unless explicitly requested, heap buffer will always be preferred to avoid potential system instability.
[2018-04-05T07:32:41,540][WARN ][i.n.u.i.MacAddressUtil ] Failed to find a usable hardware address from the network interfaces; using random bytes: 7c:9e:89:d3:c0:64:b9:79
[2018-04-05T07:32:41,719][ERROR][o.e.b.Bootstrap ] [yEpjBc2] Exception
[2018-04-05T07:32:41,728][WARN ][o.e.b.ElasticsearchUncaughtExceptionHandler] [] uncaught exception in thread [main]
… 6 more
[2018-04-05T07:32:42,503][INFO ][o.e.n.Node ] [yEpjBc2] stopping …
[2018-04-05T07:32:44,098][INFO ][o.e.n.Node ] [] initializing …
[2018-04-05T07:32:44,239][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] using [1] data paths, mounts [[/ (/dev/mapper/graylog–vg-root)]], net usable_space [11.3gb], net total_space [14.9gb], spins? [possibly], types [ext4]
[2018-04-05T07:32:44,243][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] heap size [2.3gb], compressed ordinary object pointers [true]
[2018-04-05T07:32:44,259][INFO ][o.e.n.Node ] node name [yEpjBc2] derived from node ID [yEpjBc2qTNm3OuYlP5myjQ]; set [node.name] to override
[2018-04-05T07:32:44,259][INFO ][o.e.n.Node ] version[5.6.3], pid[1689], build[1a2f265/2017-10-06T20:33:39.012Z], OS[Linux/4.4.0-116-generic/amd64], JVM[Oracle Corporation/Java HotSpot™ 64-Bit Server VM/1.8.0_161/25.161-b12]
[2018-04-05T07:32:44,259][INFO ][o.e.n.Node ] JVM arguments [-Xms2371m, -Xmx2371m, -Djava.net.preferIPv4Stack=true, -Dlog4j2.disable.jmx=true, -XX:+UseParNewGC, -XX:+UseConcMarkSweepGC, -XX:+CMSParallelRemarkEnabled, -XX:SurvivorRatio=8, -XX:MaxTenuringThreshold=1, -XX:CMSInitiatingOccupancyFraction=75, -XX:+UseCMSInitiatingOccupancyOnly, -XX:+HeapDumpOnOutOfMemoryError, -Des.path.home=/opt/graylog/elasticsearch]
[2018-04-05T07:32:45,121][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [aggs-matrix-stats]
[2018-04-05T07:32:45,122][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [ingest-common]
[2018-04-05T07:32:45,127][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-expression]
[2018-04-05T07:32:45,135][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-groovy]
[2018-04-05T07:32:45,136][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-mustache]
[2018-04-05T07:32:45,136][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-painless]
[2018-04-05T07:32:45,137][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [parent-join]
[2018-04-05T07:32:45,138][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [percolator]
[2018-04-05T07:32:45,138][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [reindex]
[2018-04-05T07:32:45,139][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty3]
[2018-04-05T07:32:45,140][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty4]
[2018-04-05T07:32:45,141][INFO ][o.e.p.PluginsService ] [yEpjBc2] no plugins loaded
[2018-04-05T07:32:47,093][INFO ][o.e.d.DiscoveryModule ] [yEpjBc2] using discovery type [zen]
[2018-04-05T07:32:47,631][INFO ][o.e.n.Node ] initialized
[2018-04-05T07:32:47,632][INFO ][o.e.n.Node ] [yEpjBc2] starting …
[2018-04-05T07:32:47,665][INFO ][i.n.u.i.PlatformDependent] Your platform does not provide complete low-level API for accessing direct buffers reliably. Unless explicitly requested, heap buffer will always be preferred to avoid potential system instability.
[2018-04-05T07:32:47,719][WARN ][i.n.u.i.MacAddressUtil ] Failed to find a usable hardware address from the network interfaces; using random bytes: e7:30:68:7f:ee:97:12:35
[2018-04-05T07:32:47,926][ERROR][o.e.b.Bootstrap ] [yEpjBc2] Exception
[2018-04-05T07:32:47,939][WARN ][o.e.b.ElasticsearchUncaughtExceptionHandler] [] uncaught exception in thread [main]
… 6 more
[2018-04-05T07:32:48,674][INFO ][o.e.n.Node ] [yEpjBc2] stopping …
[2018-04-05T07:32:49,900][INFO ][o.e.n.Node ] [] initializing …
[2018-04-05T07:32:50,044][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] using [1] data paths, mounts [[/ (/dev/mapper/graylog–vg-root)]], net usable_space [11.3gb], net total_space [14.9gb], spins? [possibly], types [ext4]
[2018-04-05T07:32:50,045][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] heap size [2.3gb], compressed ordinary object pointers [true]
[2018-04-05T07:32:50,057][INFO ][o.e.n.Node ] node name [yEpjBc2] derived from node ID [yEpjBc2qTNm3OuYlP5myjQ]; set [node.name] to override
[2018-04-05T07:32:50,058][INFO ][o.e.n.Node ] version[5.6.3], pid[1750], build[1a2f265/2017-10-06T20:33:39.012Z], OS[Linux/4.4.0-116-generic/amd64], JVM[Oracle Corporation/Java HotSpot™ 64-Bit Server VM/1.8.0_161/25.161-b12]
[2018-04-05T07:32:50,058][INFO ][o.e.n.Node ] JVM arguments [-Xms2371m, -Xmx2371m, -Djava.net.preferIPv4Stack=true, -Dlog4j2.disable.jmx=true, -XX:+UseParNewGC, -XX:+UseConcMarkSweepGC, -XX:+CMSParallelRemarkEnabled, -XX:SurvivorRatio=8, -XX:MaxTenuringThreshold=1, -XX:CMSInitiatingOccupancyFraction=75, -XX:+UseCMSInitiatingOccupancyOnly, -XX:+HeapDumpOnOutOfMemoryError, -Des.path.home=/opt/graylog/elasticsearch]
[2018-04-05T07:32:50,928][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [aggs-matrix-stats]
[2018-04-05T07:32:50,929][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [ingest-common]
[2018-04-05T07:32:50,931][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-expression]
[2018-04-05T07:32:50,933][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-groovy]
[2018-04-05T07:32:50,934][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-mustache]
[2018-04-05T07:32:50,935][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-painless]
[2018-04-05T07:32:50,935][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [parent-join]
[2018-04-05T07:32:50,935][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [percolator]
[2018-04-05T07:32:50,935][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [reindex]
[2018-04-05T07:32:50,935][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty3]
[2018-04-05T07:32:50,935][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty4]
[2018-04-05T07:32:50,936][INFO ][o.e.p.PluginsService ] [yEpjBc2] no plugins loaded
[2018-04-05T07:32:52,470][INFO ][o.e.d.DiscoveryModule ] [yEpjBc2] using discovery type [zen]
[2018-04-05T07:32:53,070][INFO ][o.e.n.Node ] initialized
[2018-04-05T07:32:53,070][INFO ][o.e.n.Node ] [yEpjBc2] starting …
[2018-04-05T07:32:53,110][INFO ][i.n.u.i.PlatformDependent] Your platform does not provide complete low-level API for accessing direct buffers reliably. Unless explicitly requested, heap buffer will always be preferred to avoid potential system instability.
[2018-04-05T07:32:53,156][WARN ][i.n.u.i.MacAddressUtil ] Failed to find a usable hardware address from the network interfaces; using random bytes: 05:db:d5:16:3f:3f:7b:e8
[2018-04-05T07:32:53,349][ERROR][o.e.b.Bootstrap ] [yEpjBc2] Exception
[2018-04-05T07:32:53,361][WARN ][o.e.b.ElasticsearchUncaughtExceptionHandler] [] uncaught exception in thread [main]
… 6 more
[2018-04-05T07:32:54,118][INFO ][o.e.n.Node ] [yEpjBc2] stopping …
[2018-04-05T07:32:55,203][INFO ][o.e.n.Node ] [] initializing …
[2018-04-05T07:32:55,358][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] using [1] data paths, mounts [[/ (/dev/mapper/graylog–vg-root)]], net usable_space [11.3gb], net total_space [14.9gb], spins? [possibly], types [ext4]
[2018-04-05T07:32:55,359][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] heap size [2.3gb], compressed ordinary object pointers [true]
[2018-04-05T07:32:55,376][INFO ][o.e.n.Node ] node name [yEpjBc2] derived from node ID [yEpjBc2qTNm3OuYlP5myjQ]; set [node.name] to override
[2018-04-05T07:32:55,377][INFO ][o.e.n.Node ] version[5.6.3], pid[1809], build[1a2f265/2017-10-06T20:33:39.012Z], OS[Linux/4.4.0-116-generic/amd64], JVM[Oracle Corporation/Java HotSpot™ 64-Bit Server VM/1.8.0_161/25.161-b12]
[2018-04-05T07:32:55,377][INFO ][o.e.n.Node ] JVM arguments [-Xms2371m, -Xmx2371m, -Djava.net.preferIPv4Stack=true, -Dlog4j2.disable.jmx=true, -XX:+UseParNewGC, -XX:+UseConcMarkSweepGC, -XX:+CMSParallelRemarkEnabled, -XX:SurvivorRatio=8, -XX:MaxTenuringThreshold=1, -XX:CMSInitiatingOccupancyFraction=75, -XX:+UseCMSInitiatingOccupancyOnly, -XX:+HeapDumpOnOutOfMemoryError, -Des.path.home=/opt/graylog/elasticsearch]
[2018-04-05T07:32:56,310][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [aggs-matrix-stats]
[2018-04-05T07:32:56,310][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [ingest-common]
[2018-04-05T07:32:56,314][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-expression]
[2018-04-05T07:32:56,315][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-groovy]
[2018-04-05T07:32:56,315][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-mustache]
[2018-04-05T07:32:56,315][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-painless]
[2018-04-05T07:32:56,315][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [parent-join]
[2018-04-05T07:32:56,316][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [percolator]
[2018-04-05T07:32:56,316][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [reindex]
[2018-04-05T07:32:56,316][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty3]
[2018-04-05T07:32:56,316][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty4]
[2018-04-05T07:32:56,317][INFO ][o.e.p.PluginsService ] [yEpjBc2] no plugins loaded
[2018-04-05T07:32:58,256][INFO ][o.e.d.DiscoveryModule ] [yEpjBc2] using discovery type [zen]
[2018-04-05T07:32:58,758][INFO ][o.e.n.Node ] initialized
[2018-04-05T07:32:58,759][INFO ][o.e.n.Node ] [yEpjBc2] starting …
[2018-04-05T07:32:58,794][INFO ][i.n.u.i.PlatformDependent] Your platform does not provide complete low-level API for accessing direct buffers reliably. Unless explicitly requested, heap buffer will always be preferred to avoid potential system instability.
[2018-04-05T07:32:58,840][WARN ][i.n.u.i.MacAddressUtil ] Failed to find a usable hardware address from the network interfaces; using random bytes: f5:a1:21:90:5f:28:15:4e
[2018-04-05T07:32:58,982][ERROR][o.e.b.Bootstrap ] [yEpjBc2] Exception
[2018-04-05T07:32:58,992][WARN ][o.e.b.ElasticsearchUncaughtExceptionHandler] [] uncaught exception in thread [main]
… 6 more
[2018-04-05T07:32:59,801][INFO ][o.e.n.Node ] [yEpjBc2] stopping …
[2018-04-05T07:33:00,927][INFO ][o.e.n.Node ] [] initializing …
[2018-04-05T07:33:01,066][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] using [1] data paths, mounts [[/ (/dev/mapper/graylog–vg-root)]], net usable_space [11.3gb], net total_space [14.9gb], spins? [possibly], types [ext4]
[2018-04-05T07:33:01,066][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] heap size [2.3gb], compressed ordinary object pointers [true]
[2018-04-05T07:33:01,090][INFO ][o.e.n.Node ] node name [yEpjBc2] derived from node ID [yEpjBc2qTNm3OuYlP5myjQ]; set [node.name] to override
[2018-04-05T07:33:01,091][INFO ][o.e.n.Node ] version[5.6.3], pid[1870], build[1a2f265/2017-10-06T20:33:39.012Z], OS[Linux/4.4.0-116-generic/amd64], JVM[Oracle Corporation/Java HotSpot™ 64-Bit Server VM/1.8.0_161/25.161-b12]
[2018-04-05T07:33:01,091][INFO ][o.e.n.Node ] JVM arguments [-Xms2371m, -Xmx2371m, -Djava.net.preferIPv4Stack=true, -Dlog4j2.disable.jmx=true, -XX:+UseParNewGC, -XX:+UseConcMarkSweepGC, -XX:+CMSParallelRemarkEnabled, -XX:SurvivorRatio=8, -XX:MaxTenuringThreshold=1, -XX:CMSInitiatingOccupancyFraction=75, -XX:+UseCMSInitiatingOccupancyOnly, -XX:+HeapDumpOnOutOfMemoryError, -Des.path.home=/opt/graylog/elasticsearch]
[2018-04-05T07:33:01,882][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [aggs-matrix-stats]
[2018-04-05T07:33:01,884][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [ingest-common]
[2018-04-05T07:33:01,885][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-expression]
[2018-04-05T07:33:01,885][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-groovy]
[2018-04-05T07:33:01,885][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-mustache]
[2018-04-05T07:33:01,887][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-painless]
[2018-04-05T07:33:01,887][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [parent-join]
[2018-04-05T07:33:01,887][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [percolator]
[2018-04-05T07:33:01,887][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [reindex]
[2018-04-05T07:33:01,888][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty3]
[2018-04-05T07:33:01,888][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty4]
[2018-04-05T07:33:01,898][INFO ][o.e.p.PluginsService ] [yEpjBc2] no plugins loaded
[2018-04-05T07:33:03,477][INFO ][o.e.d.DiscoveryModule ] [yEpjBc2] using discovery type [zen]
[2018-04-05T07:33:03,986][INFO ][o.e.n.Node ] initialized
[2018-04-05T07:33:03,986][INFO ][o.e.n.Node ] [yEpjBc2] starting …
[2018-04-05T07:33:04,020][INFO ][i.n.u.i.PlatformDependent] Your platform does not provide complete low-level API for accessing direct buffers reliably. Unless explicitly requested, heap buffer will always be preferred to avoid potential system instability.
[2018-04-05T07:33:04,070][WARN ][i.n.u.i.MacAddressUtil ] Failed to find a usable hardware address from the network interfaces; using random bytes: 04:d6:59:7d:23:bd:1e:c5
[2018-04-05T07:33:04,199][ERROR][o.e.b.Bootstrap ] [yEpjBc2] Exception
[2018-04-05T07:33:04,209][WARN ][o.e.b.ElasticsearchUncaughtExceptionHandler] [] uncaught exception in thread [main]
… 6 more
[2018-04-05T07:33:05,031][INFO ][o.e.n.Node ] [yEpjBc2] stopping …
[2018-04-05T07:33:06,158][INFO ][o.e.n.Node ] [] initializing …
[2018-04-05T07:33:06,309][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] using [1] data paths, mounts [[/ (/dev/mapper/graylog–vg-root)]], net usable_space [11.3gb], net total_space [14.9gb], spins? [possibly], types [ext4]
[2018-04-05T07:33:06,313][INFO ][o.e.e.NodeEnvironment ] [yEpjBc2] heap size [2.3gb], compressed ordinary object pointers [true]
[2018-04-05T07:33:06,329][INFO ][o.e.n.Node ] node name [yEpjBc2] derived from node ID [yEpjBc2qTNm3OuYlP5myjQ]; set [node.name] to override
[2018-04-05T07:33:06,329][INFO ][o.e.n.Node ] version[5.6.3], pid[1929], build[1a2f265/2017-10-06T20:33:39.012Z], OS[Linux/4.4.0-116-generic/amd64], JVM[Oracle Corporation/Java HotSpot™ 64-Bit Server VM/1.8.0_161/25.161-b12]
[2018-04-05T07:33:06,330][INFO ][o.e.n.Node ] JVM arguments [-Xms2371m, -Xmx2371m, -Djava.net.preferIPv4Stack=true, -Dlog4j2.disable.jmx=true, -XX:+UseParNewGC, -XX:+UseConcMarkSweepGC, -XX:+CMSParallelRemarkEnabled, -XX:SurvivorRatio=8, -XX:MaxTenuringThreshold=1, -XX:CMSInitiatingOccupancyFraction=75, -XX:+UseCMSInitiatingOccupancyOnly, -XX:+HeapDumpOnOutOfMemoryError, -Des.path.home=/opt/graylog/elasticsearch]
[2018-04-05T07:33:07,255][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [aggs-matrix-stats]
[2018-04-05T07:33:07,255][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [ingest-common]
[2018-04-05T07:33:07,265][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-expression]
[2018-04-05T07:33:07,265][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-groovy]
[2018-04-05T07:33:07,265][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-mustache]
[2018-04-05T07:33:07,265][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [lang-painless]
[2018-04-05T07:33:07,266][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [parent-join]
[2018-04-05T07:33:07,266][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [percolator]
[2018-04-05T07:33:07,266][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [reindex]
[2018-04-05T07:33:07,267][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty3]
[2018-04-05T07:33:07,267][INFO ][o.e.p.PluginsService ] [yEpjBc2] loaded module [transport-netty4]
[2018-04-05T07:33:07,269][INFO ][o.e.p.PluginsService ] [yEpjBc2] no plugins loaded
[2018-04-05T07:33:09,120][INFO ][o.e.d.DiscoveryModule ] [yEpjBc2] using discovery type [zen]
[2018-04-05T07:33:09,632][INFO ][o.e.n.Node ] initialized
[2018-04-05T07:33:09,632][INFO ][o.e.n.Node ] [yEpjBc2] starting …
[2018-04-05T07:33:09,665][INFO ][i.n.u.i.PlatformDependent] Your platform does not provide complete low-level API for accessing direct buffers reliably. Unless explicitly requested, heap buffer will always be preferred to avoid potential system instability.
[2018-04-05T07:33:09,714][WARN ][i.n.u.i.MacAddressUtil ] Failed to find a usable hardware address from the network interfaces; using random bytes: e7:00:e5:9f:60:76:88:5d
[2018-04-05T07:33:09,864][ERROR][o.e.b.Bootstrap ] [yEpjBc2] Exception
Jochen,
The logs are a lot and the community does not allow to upload .zip files or text. Any other way of uploading of uploading?
You might want to fix this so that your Elasticsearch node(s) will start.
https://gist.github.com/ or https://0bin.net/
