Statistic time reference and scale issue
hi team,
we want to select a duration to make histograms for different type of counts to analysis based on a same time duration, but we found when a count result set are sparsely distributed, the start time reference point will be moved to near somewhere first count number appears, and also the time scale size is not same when compare to other histograms for same time duration:
can we force system to using same start time reference point and same time scale and we scale down or up the time scale to make a more clear view or more high-level view?
