I am done setup of graylog with spring boot and logs are not showing in graylog web console
Please find below configuration
docker-compose
version: '2'
services:
# MongoDB:
mongodb:
image: mongo:5.0.0
volumes:
- mongo_data:/data/db
# Elasticsearch:
elasticsearch:
image: docker.elastic.co/elasticsearch/elasticsearch-oss:7.10.2
volumes:
environment:
- http.host=0.0.0.0
- transport.host=localhost
- network.host=0.0.0.0
ulimits:
memlock:
soft: -1
hard: -1
mem_limit: 1g
# Graylog:
graylog:
image: graylog/graylog:5.1.4
volumes:
environment:
- GRAYLOG_PASSWORD_SECRET=daglisecret12345
# Password: admin
- GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
- GRAYLOG_HTTP_EXTERNAL_URI=http://127.0.0.1:9000/
- GRAYLOG_WEB_ENDPOINT_URI=http://127.0.0.1:9000/api
links:
- mongodb:mongo
- elasticsearch
depends_on:
- mongodb
- elasticsearch
ports:
- 9000:9000
# Syslog TCP
- 1514:1514
# Syslog UDP
- 1514:1514/udp
# GELF TCP
- 12201:12201
# GELF UDP
- 12201:12201/udp
# Volumes for persisting data
volumes:
mongo_data:
driver: local
es_data:
driver: local
graylog_journal:
driver: local
log4j2.xml
<Configuration monitorInterval="300" status="WARN">
<properties>
<property name="LOG_HOME">/tmp/xbatch_log</property>
<property name="FILE_NAME">batchlog</property>
</properties>
<Appenders>
<Console name="Console" target="SYSTEM_OUT">
<PatternLayout pattern="%d{HH:mm:ss.SSS} [%t] %-5level %logger{36} -- %msg%n"/>
</Console>
<GELF name="gelfAppender" server="127.0.0.1" port="12201" hostName="X-Batch" protocol="UDP">
<KeyValuePair key="environment" value="DEV"/>
<KeyValuePair key="application" value="X-Batch"/>
<KeyValuePair key="additionalFields" value="{'environment': 'TEST', 'application': 'MyAPP'}"/>
</GELF>
</Appenders>
<Loggers>
<Logger additivity="false" level="error" name="com.daimler.xbatch.gssn.step">
<AppenderRef ref="gelfAppender"/>
</Logger>
<Root level="info">
<AppenderRef ref="Console"/>
</Root>
</Loggers>
</Configuration>
pom.xml
<dependency>
<groupId>org.springframework.boot</groupId>
<artifactId>spring-boot-starter-web</artifactId>
<exclusions>
<exclusion>
<artifactId>spring-boot-starter-logging</artifactId>
</exclusion>
</exclusions>
</dependency>
<dependency>
<groupId>org.graylog2.log4j2</groupId>
<artifactId>log4j2-gelf</artifactId>
<version>1.3.1</version>
</dependency>
<dependency>
<artifactId>spring-boot-starter-log4j2</artifactId>
<version>2.0.4.RELEASE</version>
</dependency>
