SMTP Encryption Issue
I am having trouble configuring Graylog to send encrypted email. I used this command from the docs.
sudo graylog-ctl set-email-config smtp.our_domain.com --user=our_user --password=our_password --port 587
I receive the below error:
Could not send test alert notification
Sending test alert notification failed with message: Sending the email to the following server failed : smtp.our_domain:587
Our email admin advises that the email logs indicate that connection is not encrypted. Graylog is sending the email unencrypted. It looks configured correctly?
transport_email_use_auth = true
transport_email_use_tls = true
transport_email_use_ssl = true
Thank You!
# If you are running more than one instances of graylog-server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting graylog-server from init scripts or similar.
node_id_file = /var/opt/graylog/graylog-server-node-id
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
password_secret = our_secret
# the default root user is named 'admin'
root_username = admin
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 = our_secret
# Default is empty
#root_email = ""
# The time zone setting of the root user.
# Default is UTC
root_timezone = EST5EDT
plugin_dir = /opt/graylog/plugin
# REST API listen URI. Must be reachable by other graylog-server nodes if you run a cluster.
rest_listen_uri = http://0.0.0.0:9000/api
# Web interface listen URI
web_listen_uri = http://0.0.0.0:9000/
# REST API transport address. Defaults to the value of rest_listen_uri. Exception: If rest_listen_uri
# is set to a wildcard IP address (0.0.0.0) the first non-loopback IPv4 system address is used.
# If set, his will be promoted in the cluster discovery APIs, so other nodes may try to connect on
# this address and it is used to generate URLs addressing entities in the REST API. (see rest_listen_uri)
# You will need to define this, if your Graylog server is running behind a HTTP proxy that is rewriting
# the scheme, host name or URI.
# Web interface endpoint URI. This setting can be overriden on a per-request basis with the X-Graylog-Server-URL header.
# Default: $rest_transport_uri
# Enable CORS headers for REST api. This is necessary for JS-clients accessing the server directly.
# If these are disabled, modern browsers will not be able to retrieve resources from the server.
# This is disabled by default. Uncomment the next line to enable it.
rest_enable_cors = true
# Enable GZIP support for REST api. This compresses API responses and therefore helps to reduce
# overall round trip times. This is disabled by default. Uncomment the next line to enable it.
#rest_enable_gzip = true
# Enable HTTPS support for the REST API. This secures the communication with the REST API with
# TLS to prevent request forgery and eavesdropping. This is disabled by default. Uncomment the
# next line to enable it.
#rest_enable_tls = true
# The X.509 certificate file to use for securing the REST API.
#rest_tls_cert_file = /path/to/graylog2.crt
# The private key to use for securing the REST API.
#rest_tls_key_file = /path/to/graylog2.key
# The password to unlock the private key used for securing the REST API.
#rest_tls_key_password = secret
# The maximum size of a single HTTP chunk in bytes.
#rest_max_chunk_size = 8192
#rest_max_header_size = 8192
# The maximal length of the initial HTTP/1.1 line in bytes.
#rest_max_initial_line_length = 4096
# The size of the thread pool used exclusively for serving the REST API.
#rest_thread_pool_size = 16
# The size of the worker thread pool used exclusively for serving the REST API.
#rest_worker_threads_max_pool_size = 16
#no_retention = false
elasticsearch_shards = 4
elasticsearch_replicas = 1
# be enabled with care. See also: http://graylog2.org/resources/documentation/general/queries
allow_highlighting = false
# requires authentication.
elasticsearch_hosts = http://our_ip:9200
# Maximum amount of time to wait for successfull connection to Elasticsearch HTTP port.
# be tore down.
elasticsearch_max_total_connections = 20
# elasticsearch server).
elasticsearch_max_total_connections_per_route = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
#elasticsearch_discovery_frequency = 30s
# Elasticsearch documentation: http://www.elasticsearch.org/guide/reference/index-modules/analysis/
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
# Start server with --statistics flag to see buffer utilization.
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
message_journal_dir = /var/opt/graylog/data/journal
message_journal_max_size = 1gb
async_eventbus_processors = 2
# stream_processing_timeout = 2000
# stream_processing_max_faults = 3
# Length of the interval in seconds in which the alert conditions for all streams should be checked
# and alarms are being sent.
alert_check_interval = 60
# Since 0.21 the graylog server supports pluggable output modules. This means a single message can be written to multiple
# messages end up. This setting is specified in milliseconds.
#stale_master_timeout = 2000
# shutdown_timeout = 30000
# MongoDB Configuration
mongodb_uri = mongodb://127.0.0.1:27017/graylog
# Raise this according to the maximum connections your MongoDB server can handle if you encounter MongoDB connection problems.
mongodb_max_connections = 100
# If mongodb_max_connections is 100, and mongodb_threads_allowed_to_block_multiplier is 5, then 500 threads can block. More than that and an exception will be thrown.
# http://api.mongodb.org/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Drools Rule File (Use to rewrite incoming log messages)
# See: http://graylog2.org/resources/documentation/general/rewriting
# Email transport
transport_email_hostname = smtp.our_domain.com
transport_email_port = 587
transport_email_auth_username = our_account
transport_email_auth_password = our_password
transport_email_from_email = graylog@graylog
transport_email_web_interface_url = http://graylog
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
# HTTP proxy for outgoing HTTP calls
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# Disable the index range calculation on all open/available indices and only calculate the range for the latest
# index. This may speed up index cycling on systems with large indices but it might lead to wrong search results
# in regard to the time range of the messages (i. e. messages within a certain range may not be found). The default
# is to calculate the time range on all open/available indices.
#disable_index_range_calculation = true
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Enable collection of Graylog-related metrics into MongoDB
#enable_metrics_collection = false
# Disable the use of SIGAR for collecting system stats
#disable_sigar = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
dashboard_widget_default_cache_time = 10s
# Automatically load content packs in "content_packs_dir" on the first start of Graylog.
content_packs_loader_enabled = true
# The directory which contains content packs which should be loaded on the first start of Graylog.
content_packs_dir = /opt/graylog/contentpacks
# A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
# the first start of Graylog.
content_packs_auto_load = grok-patterns.json,content_pack_appliance.json
Please edit your first post and format the configuration snippet properly for better readability:
https://help.github.com/articles/creating-and-highlighting-code-blocks/
is_master = true
# Default is empty
#root_email = ""
# Default is UTC
# be tore down.
# Default: empty
# Default: 1m
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
# Email transport
# Default: 5s
# Default: 10s
# Default: 10s
# cycled indices.
is_master = true
# Default is empty
#root_email = ""
# Default is UTC
# be tore down.
# Default: empty
# Default: 1m
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
# Email transport
# Default: 5s
# Default: 10s
# Default: 10s
# cycled indices.
What type of connection does your SMTP server expect?
Plaintext SMTP (usually port 25/tcp)?
Plaintext SMTP followed by a TLS connection upgrade via STARTTLS (usually port 587/tcp)?
SMTP over SSL (usually port 465/tcp)?
Take a look at the parameters of the “email-config” command of graylog-ctl and set the connection parameters accordingly:
http://docs.graylog.org/en/2.4/pages/configuration/graylog_ctl.html#configuration-commands
Hint: It’s not useful to require SSL and TLS (via STARTTLS) at the same time.
Also make sure to check the logs of your Graylog node.
http://docs.graylog.org/en/2.4/pages/configuration/file_location.html#omnibus-graylog
Thank you, the change to port 465 worked.
