I have recently upgraded graylog from 3.1 to 3.3.2 and now when running a search and selecting “Show top values”, graylog only shows the top 15 results. Is there any way to expand this beyond the top 15?
Previously in the older version you would get more than the top 15 results.
You need to edit widget and click on field (@field_name) in ROWS or COLUMNS, and there you can select max number of results.
So there is a way.
Thank you very much.
