@gsmith @ttsandrew Below is the most recent logs.
As can be seen that graylog is starting well and I dont see any error related to UI no opening up.
Even though I can see error specfic to an inputs for ‘Beats’ but that shouldnt lead to GUI not opening up.
2022-05-09T01:23:55.996Z INFO [ServerBootstrap] Graylog server 4.2.7+879e651 starting up
2022-05-09T01:23:55.997Z INFO [ServerBootstrap] JRE: Red Hat, Inc. 1.8.0_302 on Linux 4.18.0-305.3.1.el8.x86_64
2022-05-09T01:23:55.997Z INFO [ServerBootstrap] Deployment: rpm
2022-05-09T01:23:55.997Z INFO [ServerBootstrap] OS: CentOS Linux 8 (centos)
2022-05-09T01:23:55.997Z INFO [ServerBootstrap] Arch: amd64
2022-05-09T01:23:56.035Z INFO [PeriodicalsService] Starting 29 periodicals ...
2022-05-09T01:23:56.036Z INFO [Periodicals] Starting [org.graylog2.periodical.ThroughputCalculator] periodical in [0s], polling every [1s].
2022-05-09T01:23:56.058Z INFO [Periodicals] Starting [org.graylog.plugins.pipelineprocessor.periodical.LegacyDefaultStreamMigration] periodical, running forever.
2022-05-09T01:23:56.106Z INFO [PeriodicalsService] Not starting [org.graylog2.periodical.AlertScannerThread] periodical. Not configured to run on this node.
2022-05-09T01:23:56.106Z INFO [Periodicals] Starting [org.graylog2.periodical.BatchedElasticSearchOutputFlushThread] periodical in [0s], polling every [1s].
2022-05-09T01:23:56.107Z INFO [Periodicals] Starting [org.graylog2.periodical.ClusterHealthCheckThread] periodical in [120s], polling every [20s].
2022-05-09T01:23:56.130Z INFO [PeriodicalsService] Not starting [org.graylog2.periodical.ContentPackLoaderPeriodical] periodical. Not configured to run on this node.
2022-05-09T01:23:56.130Z INFO [Periodicals] Starting [org.graylog2.periodical.GarbageCollectionWarningThread] periodical, running forever.
2022-05-09T01:23:56.142Z INFO [Periodicals] Starting [org.graylog2.periodical.IndexerClusterCheckerThread] periodical in [0s], polling every [30s].
2022-05-09T01:23:56.150Z INFO [Periodicals] Starting [org.graylog2.periodical.IndexRetentionThread] periodical in [0s], polling every [300s].
2022-05-09T01:23:56.169Z INFO [Periodicals] Starting [org.graylog2.periodical.IndexRotationThread] periodical in [0s], polling every [10s].
2022-05-09T01:23:56.183Z INFO [Periodicals] Starting [org.graylog2.periodical.NodePingThread] periodical in [0s], polling every [1s].
2022-05-09T01:23:56.188Z INFO [Periodicals] Starting [org.graylog2.periodical.VersionCheckThread] periodical in [300s], polling every [1800s].
2022-05-09T01:23:56.209Z INFO [Periodicals] Starting [org.graylog2.periodical.ThrottleStateUpdaterThread] periodical in [1s], polling every [1s].
2022-05-09T01:23:56.210Z INFO [Periodicals] Starting [org.graylog2.events.ClusterEventPeriodical] periodical in [0s], polling every [1s].
2022-05-09T01:23:56.212Z INFO [Periodicals] Starting [org.graylog2.events.ClusterEventCleanupPeriodical] periodical in [0s], polling every [86400s].
2022-05-09T01:23:56.213Z INFO [Periodicals] Starting [org.graylog2.periodical.ClusterIdGeneratorPeriodical] periodical, running forever.
2022-05-09T01:23:56.213Z INFO [Periodicals] Starting [org.graylog2.periodical.IndexRangesMigrationPeriodical] periodical, running forever.
2022-05-09T01:23:56.225Z INFO [Periodicals] Starting [org.graylog2.periodical.IndexRangesCleanupPeriodical] periodical in [15s], polling every [3600s].
2022-05-09T01:23:56.229Z INFO [connection] Opened connection [connectionId{localValue:5, serverValue:75}] to localhost:27017
2022-05-09T01:23:56.232Z INFO [LegacyDefaultStreamMigration] Legacy default stream has no connections, no migration needed.
2022-05-09T01:23:56.243Z INFO [connection] Opened connection [connectionId{localValue:6, serverValue:74}] to localhost:27017
2022-05-09T01:23:56.249Z INFO [connection] Opened connection [connectionId{localValue:9, serverValue:78}] to localhost:27017
2022-05-09T01:23:56.252Z INFO [PeriodicalsService] Not starting [org.graylog2.periodical.UserPermissionMigrationPeriodical] periodical. Not configured to run on this node.
2022-05-09T01:23:56.253Z INFO [Periodicals] Starting [org.graylog2.periodical.ConfigurationManagementPeriodical] periodical, running forever.
2022-05-09T01:23:56.253Z INFO [Periodicals] Starting [org.graylog2.periodical.TrafficCounterCalculator] periodical in [0s], polling every [1s].
2022-05-09T01:23:56.254Z INFO [Periodicals] Starting [org.graylog2.indexer.fieldtypes.IndexFieldTypePollerPeriodical] periodical in [0s], polling every [3600s].
2022-05-09T01:23:56.255Z INFO [Periodicals] Starting [org.graylog.scheduler.periodicals.ScheduleTriggerCleanUp] periodical in [120s], polling every [86400s].
2022-05-09T01:23:56.261Z INFO [Periodicals] Starting [org.graylog2.periodical.ESVersionCheckPeriodical] periodical in [0s], polling every [30s].
2022-05-09T01:23:56.262Z INFO [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredSidecarsThread] periodical in [0s], polling every [600s].
2022-05-09T01:23:56.266Z INFO [Periodicals] Starting [org.graylog.plugins.sidecar.periodical.PurgeExpiredConfigurationUploads] periodical in [0s], polling every [600s].
2022-05-09T01:23:56.267Z INFO [Periodicals] Starting [org.graylog.plugins.views.search.db.SearchesCleanUpJob] periodical in [3600s], polling every [28800s].
2022-05-09T01:23:56.267Z INFO [Periodicals] Starting [org.graylog.events.periodicals.EventNotificationStatusCleanUp] periodical in [120s], polling every [86400s].
2022-05-09T01:23:56.268Z INFO [Periodicals] Starting [org.graylog.plugins.collector.periodical.PurgeExpiredCollectorsThread] periodical in [0s], polling every [3600s].
2022-05-09T01:23:56.279Z INFO [connection] Opened connection [connectionId{localValue:8, serverValue:77}] to localhost:27017
2022-05-09T01:23:56.285Z INFO [connection] Opened connection [connectionId{localValue:7, serverValue:76}] to localhost:27017
2022-05-09T01:23:56.290Z INFO [connection] Opened connection [connectionId{localValue:10, serverValue:79}] to localhost:27017
2022-05-09T01:23:56.434Z INFO [JerseyService] Enabling CORS for HTTP endpoint
2022-05-09T01:23:58.549Z INFO [NetworkListener] Started listener bound to [10.41.144.233:9000]
2022-05-09T01:23:58.551Z INFO [HttpServer] [HttpServer] Started.
2022-05-09T01:23:58.551Z INFO [JerseyService] Started REST API at <10.41.144.233:9000>
2022-05-09T01:23:58.551Z INFO [ServiceManagerListener] Services are healthy
2022-05-09T01:23:58.553Z INFO [ServerBootstrap] Services started, startup times in ms: {JobSchedulerService [RUNNING]=196, PrometheusExporter [RUNNING]=196, FailureHandlingService [RUNNING]=196, EtagService [RUNNING]=197, OutputSetupService [RUNNING]=197, BufferSynchronizerService [RUNNING]=198, GracefulShutdownService [RUNNING]=199, UrlWhitelistService [RUNNING]=199, InputSetupService [RUNNING]=200, LocalKafkaMessageQueueReader [RUNNING]=200, LocalKafkaMessageQueueWriter [RUNNING]=200, UserSessionTerminationService [RUNNING]=202, LocalKafkaJournal [RUNNING]=206, PeriodicalsService [RUNNING]=244, ConfigurationEtagService [RUNNING]=259, MongoDBProcessingStatusRecorderService [RUNNING]=266, LookupTableService [RUNNING]=318, StreamCacheService [RUNNING]=375, JerseyService [RUNNING]=2524}
2022-05-09T01:23:58.561Z INFO [ServerBootstrap] Graylog server up and running.
2022-05-09T01:23:58.562Z INFO [InputSetupService] Triggering launching persisted inputs, node transitioned from Uninitialized [LB:DEAD] to Running [LB:ALIVE]
2022-05-09T01:23:58.743Z INFO [InputStateListener] Input [Syslog TCP/6259fa8f8bb8cd6e2a8b11cf] is now STARTING
2022-05-09T01:23:58.768Z INFO [InputStateListener] Input [Syslog UDP/6259fa5a8bb8cd6e2a8b1192] is now STARTING
2022-05-09T01:23:58.770Z INFO [InputStateListener] Input [Beats/62702df4d8de1f2d3397b107] is now STARTING
2022-05-09T01:23:58.822Z INFO [InputStateListener] Input [Beats/625e482dd8de1f2d33844d52] is now STARTING
2022-05-09T01:23:58.905Z WARN [AbstractTcpTransport] receiveBufferSize (SO_RCVBUF) for input Beats2Input{title=Beats, type=org.graylog.plugins.beats.Beats2Input, nodeId=null} (channel [id: 0xcfd9c287, L:/0:0:0:0:0:0:0:0%0:5044]) should be >= 1048576 but is 425984.
2022-05-09T01:23:58.908Z WARN [AbstractTcpTransport] receiveBufferSize (SO_RCVBUF) for input SyslogTCPInput{title=SYSLOG TCP, type=org.graylog2.inputs.syslog.tcp.SyslogTCPInput, nodeId=58aedeab-6855-4a75-9826-d00e8dd18ac0} (channel [id: 0x5ce3f4f1, L:/0:0:0:0:0:0:0:0%0:1514]) should be >= 1048576 but is 425984.
2022-05-09T01:23:58.910Z WARN [AbstractTcpTransport] Failed to start channel for input Beats2Input{title=LocalHost - 127.0.0.1 - 5044 Port, type=org.graylog.plugins.beats.Beats2Input, nodeId=58aedeab-6855-4a75-9826-d00e8dd18ac0}
io.netty.channel.unix.Errors$NativeIoException: bind(..) failed: Address already in use
2022-05-09T01:23:58.914Z INFO [InputStateListener] Input [Beats/625e482dd8de1f2d33844d52] is now RUNNING
2022-05-09T01:23:58.916Z INFO [InputStateListener] Input [Syslog TCP/6259fa8f8bb8cd6e2a8b11cf] is now RUNNING
2022-05-09T01:23:58.923Z ERROR [InputLauncher] The [org.graylog.plugins.beats.Beats2Input] input with ID <62702df4d8de1f2d3397b107> misfired. Reason: bind(..) failed: Address already in use.
org.graylog2.plugin.inputs.MisfireException: org.graylog2.plugin.inputs.MisfireException: io.netty.channel.unix.Errors$NativeIoException: bind(..) failed: Address already in use
at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:158) ~[graylog.jar:?]
at org.graylog2.shared.inputs.InputLauncher$1.run(InputLauncher.java:84) [graylog.jar:?]
at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:180) [graylog.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_302]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_302]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_302]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_302]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_302]
Caused by: org.graylog2.plugin.inputs.MisfireException: io.netty.channel.unix.Errors$NativeIoException: bind(..) failed: Address already in use
at org.graylog2.plugin.inputs.transports.AbstractTcpTransport.launch(AbstractTcpTransport.java:224) ~[graylog.jar:?]
at org.graylog2.plugin.inputs.MessageInput.launch(MessageInput.java:155) ~[graylog.jar:?]
... 7 more
Caused by: io.netty.channel.unix.Errors$NativeIoException: bind(..) failed: Address already in use
2022-05-09T01:23:58.946Z INFO [InputStateListener] Input [Beats/62702df4d8de1f2d3397b107] is now FAILED
2022-05-09T01:23:58.960Z INFO [InputStateListener] Input [Syslog UDP/6259fa5a8bb8cd6e2a8b1192] is now RUNNING
I am still getting ‘this site cant be reached error’ on GUI.
