I am facing an issue to configure HTTPS for Graylog Docker Container. I followed all instruction for generating self signed certificate and add to java keystore. when I run docker-compose up then Graylog error “unreadable or missing http private key”. I have added all configuration in docker-compose.yml file but no luck. Please help on this, below my docker-compose.yml file,
version: ‘2’
services:
mongodb:
image: mongo:3
volumes:
- mongo_data:/data/db
elasticsearch:
image: docker.elastic.co/elasticsearch/elasticsearch-oss:6.8.5
volumes:
environment:
- http.host=0.0.0.0
- transport.host=localhost
- network.host=0.0.0.0
- “ES_JAVA_OPTS=-Xms512m -Xmx512m”
ulimits:
memlock:
soft: -1
hard: -1
mem_limit: 1g
graylog:
image: graylog/graylog:3.3
volumes:
- /usr/share/graylog/data/journal/certs/graylog-key.pem:/home/mydrive/certs/graylog-key.pem
- /usr/share/graylog/data/journal/certs/graylog-certificate.pem:/home/mydrive/certs/graylog-cert.pem
environment:
- GRAYLOG_IS_MASTER= true
# Password: admin
- GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
- GRAYLOG_SERVER_JAVA_OPTS= -Xms1g -Xmx1g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -Djavax.net.ssl.trustStore=/home/mydrive/certs/cacerts.jks
- GRAYLOG_HTTP_ENABLE_TLS=true
- GRAYLOG_HTTP_TLS_CERT_FILE=/home/mydrive/certs/graylog-cert.pem
- GRAYLOG_HTTP_TLS_KEY_FILE=/home/mydrive/certs/graylog-key.pem
- GRAYLOG_HTTP_TLS_KEY_PASSWORD=secret
- GRAYLOG_HTTP_PUBLISH_URI=https://10.7.56.75:9001/
- GRAYLOG_PASSWORD_SECRET=tYApUfKmhkg7ca#l
- GRAYLOG_HTTP_EXTERNAL_URI=https://10.7.56.75:9001/
- GRAYLOG_REST_ENABLE_TLS=true
- GRAYLOG_WEB_ENABLE_TLS=true
- GRAYLOG_REST_TLS_CERT_FILE= /home/mydrive/certs/graylog-cert.pem
- GRAYLOG_REST_TLS_KEY_FILE= /home/mydrive/certs/graylog-key.pem
- GRAYLOG_WEB_TLS_CERT_FILE= /home/mydrive/certs/graylog-cert.pem
- GRAYLOG_WEB_TLS_KEY_FILE= /home/mydrive/certs/graylog-key.pem
- GRAYLOG_REST_TRANSPORT_URI= https://graylog.prod.lan:9001/api
- GRAYLOG_ELASTICSEARCH_HOSTS= http://elasticsearch:9200 ,http://elasticsearch2:9200
- GRAYLOG_MONGODB_URI= mongodb://mongo:27017,mongo2:27017/graylog?replicaSet=graylog
links:
- mongodb:mongo
- elasticsearch
depends_on:
- mongodb
- elasticsearch
ports:
- 443:9001
- 514:514/tcp
- 514:514/udp
- 5044:5044/tcp
- 9001:9001
- 9350:9350
- 12202-12300:12202-12300/tcp
- 12202-12300:12202-12300/udp
- 12900:12900
Volumes for persisting data, see https://docs.docker.com/engine/admin/volumes/volumes/
volumes:
mongo_data:
driver: local
es_data:
driver: local
graylog_journal:
driver: local
