smartao
(Sergei)
September 6, 2019, 5:48pm
1
Hello
I am testing graylog on containers and would love to set the node_id of the container, but regardless of what do node_id is automatically generated.
I am going up the environment as follows
docker run --name mongo -d mongo:3
docker run --name elasticsearch \
-e "http.host=0.0.0.0" \
-e "ES_JAVA_OPTS=-Xms512m -Xmx512m" \
-d docker.elastic.co/elasticsearch/elasticsearch-oss:6.7.0
docker run --name graylog --link mongo --link elasticsearch \
-p 9000:9000 -p 12201:12201 -p 1514:1514 \
-e GRAYLOG_NODE_ID="dec7fa69-ae3b-488f-970d-ef707e727345" \
-e GRAYLOG_HTTP_EXTERNAL_URI="http://10.2.1.236:9000/" \
-e GRAYLOG_ROOT_PASSWORD_SHA2=8d969eef6ecad3c29a3a629280e686cf0c3f5d5a86aff3ca12020c923adc6c92 \
-e GRAYLOG_PASSWORD_SECRET=fGoTI07CooB6xNy5sdPVSKSuq6QSu2QyWf6G9z3haolgwbERTQ9ZbfbF6hxRYbJMMAlEZX7CXHxJLBkNyfM0420u8aFuZy9M \
-d graylog/graylog:3.1
Using GRAYLOG_NODE_ID environment variable, but logs show that ID was automatically generated:
2019-09-06 16:56:18,840 INFO : org.graylog2.plugin.system.NodeId - No node ID file found. Generated: 6c141513-2bd8-42f0-9f30-98d790c27833
I did some other tests using the variable in other ways
-e GRAYLOG_NODE_ID=yyyyyf61-3876-4005-89c1-34204efxxxxx
-e GRAYLOG_NODE_ID=1234
-e GRAYLOG_NODE_ID='12'
I also tested pointing the ID file of my computer directly:
-v /tmp/node-id:/etc/graylog/server/node-id:ro \
-v /tmp/node-id:/opt/graylog/config/node-id:ro \
Unfortunately the ID is always randomly generated.
I wonder if it is possible to manually set the ID for graylog in container.
tks
jan
(Jan Doberstein)
September 9, 2019, 7:08am
2
the setting name is node_id_file.
If you have that available from the outside, in the correct location it will work. The file location in the docker image is /usr/share/graylog/config/node-id
smartao
(Sergei)
September 9, 2019, 2:41pm
3
Hello Jan
Really didn’t know the correct path to the file in the image was this:
What I find strange is that I made the adjustment but still graylog doesn’t recognize the node id file.
example:
cat /tmp/node-id
9a71d762-c6a1-47fb-bcfe-3917424expto
-e GRAYLOG_HTTP_EXTERNAL_URI="http://127.0.0.1:9000/" \
-v /tmp/node-id:/usr/share/graylog/config/node-id \
I also tested declaring the file:
-e GRAYLOG_NODE_ID_FILE=/tmp/node-id \
Is there any more configuration to be done?
thank you very much
jan
(Jan Doberstein)
September 9, 2019, 2:46pm
4
I have that via volumen mount in docker compose:
so it is working -
smartao
(Sergei)
September 12, 2019, 9:28pm
5
Hello Jan
I really couldn’t make it work using the example you provided.
Anyway I searched inside the container and realized that when there is no node-id file a new one is generated in the location:
/usr/share/graylog/data/config/node-id
So I made the file assembly pointing this location, was as follows.
-v /tmp/node-id:/usr/share/graylog/data/config/node-id
The complete syntax was as follows:
-v /tmp/node-id:/usr/share/graylog/data/config/node-id \
With that graylog recognized the file and accepted the ID.
As always thank you very much for all the help.
Enjoyed, I find it very interesting the github repository learned several things from it.
Tks
