we have a plugin that’s storing information in the MongoDB. When we try to store a document/class with org.joda.time.DateTime it fails with following exception:
org.bson.codecs.configuration.CodecConfigurationException: Can’t find a codec for class org.joda.time.DateTime.
The MongoDB is the interface setup as followed:
PluginClass(MongoConnection mongoConnection, MongoJackObjectMapperProvider mapperProvider,[...]) throws IOException {
final DBCollection dbCollection = mongoConnection.getDatabase().getCollection(collectionName);
this.set_collection = JacksonDBCollection.wrap(dbCollection, Information.class, String.class, mapperProvider.get());
The mapper is indeed of the type org.graylog2.bindings.providers.MongoJackObjectMapperProvider.
Which, as far as my understanding goes, is the needed mapper for this, because it brings additional support for de/serialising classes such as yoda.DateTime.
main/java/org/graylog2/bindings/providers/MongoJackObjectMapperProvider.java:
import org.joda.time.DateTime;
@Singleton
public class MongoJackObjectMapperProvider implements Provider<ObjectMapper> {
private final ObjectMapper objectMapper;
@Inject
public MongoJackObjectMapperProvider(ObjectMapper objectMapper) {
// add the mongojack specific stuff on a copy of the original ObjectMapper to avoid changing the singleton instance
this.objectMapper = objectMapper.copy()
.addHandler(new ReplaceUnknownSubtypesWithFallbackHandler())
.setPropertyNamingStrategy(new PreserveLeadingUnderscoreStrategy())
.registerModule(new SimpleModule("JSR-310-MongoJack")
.addSerializer(ZonedDateTime.class, new MongoZonedDateTimeSerializer())
.addDeserializer(ZonedDateTime.class, new MongoZonedDateTimeDeserializer())
.addSerializer(DateTime.class, new MongoJodaDateTimeSerializer())
.addDeserializer(DateTime.class, new MongoJodaDateTimeDeserializer()));
MongoJackModule.configure(this.objectMapper);
EncryptedValueMapperConfig.enableDatabase(this.objectMapper);
The .configure() is also mentioned in the documentation:
http://javadox.com/org.mongojack/mongojack/2.0.0-RC5/org/mongojack/JacksonDBCollection.html#wrap(com.mongodb.DBCollection,%20java.lang.Class,%20java.lang.Class,%20com.fasterxml.jackson.databind.ObjectMapper)
I’m pretty much at a loss here. I looked at how other components inside Graylog handle this (e.g. OutputServiceImpl.java, ClusterConfigServiceImpl) and then modeled my code in likeness.
I appreciate any input and ideas. Thanks.
