Hello. I have the same problem like in Problem with JSON extractor
I have JSON messages:
{"timestamp":"2017-11-13T17:09:32.878Z","level":"INFO","message":"Exchange [creators/createAllExchangersForUser]: Currencies to gen: ","meta":""}
After enabling JSON extractor for message field I have errors in my server log:
2017-11-13T16:58:56.475Z ERROR [BlockingBatchedESOutput] Unable to flush message buffer
java.lang.ClassCastException: Cannot cast java.lang.String to org.joda.time.DateTime
at java.lang.Class.cast(Class.java:3369) ~[?:1.8.0_151]
at org.graylog2.plugin.Message.getFieldAs(Message.java:384) ~[graylog.jar:?]
at org.graylog2.plugin.Message.getTimestamp(Message.java:189) ~[graylog.jar:?]
at org.graylog2.indexer.messages.Messages.propagateFailure(Messages.java:181) ~[graylog.jar:?]
at org.graylog2.indexer.messages.Messages.bulkIndex(Messages.java:145) ~[graylog.jar:?]
at org.graylog2.outputs.ElasticSearchOutput.writeMessageEntries(ElasticSearchOutput.java:111) ~[graylog.jar:?]
at org.graylog2.outputs.BlockingBatchedESOutput.flush(BlockingBatchedESOutput.java:129) [graylog.jar:?]
at org.graylog2.outputs.BlockingBatchedESOutput.writeMessageEntry(BlockingBatchedESOutput.java:110) [graylog.jar:?]
at org.graylog2.outputs.BlockingBatchedESOutput.write(BlockingBatchedESOutput.java:92) [graylog.jar:?]
at org.graylog2.buffers.processors.OutputBufferProcessor$1.run(OutputBufferProcessor.java:191) [graylog.jar:?]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_151]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_151]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_151]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_151]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_151]
The timestamp field is vaild. How I can resolve this issue?
Graylog 2.3.2+3df951e on localhost (Oracle Corporation 1.8.0_151 on Linux 4.4.0-78-generic)
