i use mvn package to build graylog-plugin-collector.
this is the error message:
Test set: org.graylog.plugins.collector.collectors.CollectorServiceImplTest
Tests run: 10, Failures: 0, Errors: 4, Skipped: 0, Time elapsed: 6.299 sec <<< FAILURE! - in org.graylog.plugins.collector.collectors.CollectorServiceImplTest
testFindByNodeId(org.graylog.plugins.collector.collectors.CollectorServiceImplTest) Time elapsed: 0.564 sec <<< ERROR!
org.mongojack.MongoJsonMappingException: Error mapping BSON to POJOs
at org.graylog.plugins.collector.collectors.CollectorServiceImplTest.testFindByNodeId(CollectorServiceImplTest.java:140)
Caused by: com.fasterxml.jackson.databind.JsonMappingException:
Can not construct instance of org.graylog.plugins.collector.collectors.CollectorNodeDetails, problem: Unresolved compilation problem:
AutoValue_CollectorNodeDetails cannot be resolved to a type
at [Source: N/A; line: -1, column: -1] (through reference chain: org.graylog.plugins.collector.collectors.CollectorImpl["node_details"])
Caused by: java.lang.Error:
testAll(org.graylog.plugins.collector.collectors.CollectorServiceImplTest) Time elapsed: 0.044 sec <<< ERROR!
at org.graylog.plugins.collector.collectors.CollectorServiceImplTest.testAll(CollectorServiceImplTest.java:99)
testFindById(org.graylog.plugins.collector.collectors.CollectorServiceImplTest) Time elapsed: 0.025 sec <<< ERROR!
at org.graylog.plugins.collector.collectors.CollectorServiceImplTest.testFindById(CollectorServiceImplTest.java:119)
testSaveFirstRecord(org.graylog.plugins.collector.collectors.CollectorServiceImplTest) Time elapsed: 0.024 sec <<< ERROR!
java.lang.Error:
