Hello there! I just discovered the pipeline feature, which allows me to do things like tag messages with a field if they come from certain subnets, which is great! Unfortunately, I haven’t figured out how to get the pipeline processor to run on all the older messages; the fields that I am attempting to use are all already available within the stored messages; I don’t need “raw” information of any kind. Is it possible to “re-run” the pipelines on older data?
If not, is there a way for me to programmatically tag all the old messages that match my rule, essentially manually running the pipeline? Really all it’s doing is running something like:
rule "is_ci_ip"
has_field("http_src") && (cidr_match("<subnet1>", to_ip($message.http_src)) || cidr_match("<subnet2>", to_ip($message.http_src)) || ...)
set_field("is_ci_ip", true);
So I could easily do this with an external script, if there were an easy way to set fields. Thanks!
