Run several outputs
Hey, can anyone help me with configuring outputs?
I have a cluster with ES configured as database but I’d need to have same output on a different place (file for example). But when I enable stream output graylog stops writing stuff to my ES. Is there a way to make it works?
Writing the Output of a Stream to a file should not stop the messages from beeing ingested to Elasticsearch from Graylog.
Maybe you can give some more details, like version logfiles and configuration.
hm, yes. Sorry, after some changes I managed that to work properly. Anyway thx for help!!
