Hi Team
How to restrict graylog to output the messages from only one stream using graylog outputs?
Srumith.
Hi Team
Srumith.
You would create an output only for the desired stream.
Did the same.
But still I find the messages related to other streams.
Is there any flag kind of thing which I need to enable/disable?
Please elaborate in greater detail what exactly you mean with that.
Sure.
I have two streams Stream A and Stream B.
Configured an output called Output A with destination as Kibana for Stream A
In Kibana, I have configured elasticURL as http://<host>:9200/.
Now, when I check Kibana, I have messages related to Stream A and Stream B.
I am not expecting messages related to Stream B on Kibana.
What output have you configured exactly and what’s the configuration?
Gelf Output I have configured. Following is the configuration -
connect_timeout: 1000
hostname: ##.##.##.##
max_inflight_sends: 512
port: 5601
protocol: TCP
queue_size: 512
reconnect_delay: 500
tcp_keep_alive: false
tcp_no_delay: false
tls_trust_cert_chain:
tls_verification_enabled: false
That looks like a GELF output. Where exactly are you sending the messages and what is the recipient doing with them?
Sending messages to Kibana.
I actually have metrics and logs reported to graylog.
I want only metrics to get forwarded from Graylog to Kibana, so that I can visualize them.
5601 is the Kibana port I have configured for Gelf Output.
And I am connecting to Elastic directly from Kibana, giving elasticsearch url as 9200.
Or if you want us to rephrase the question - how to configure output in graylog for a particular stream and forward messages to Kibana?
Kibana is a frontend for Elasticsearch, it doesn’t receive or process messages itself.
So where exactly are you sending the messages with the GELF output?
Hint: It has to be something with a GELF input.
Correct.
So can I forward specific stream data from Graylog to another elasticsearch instance using Graylog Outputs?
You could do that if you have a receiver reading GELF messages and writing them into Elasticsearch.
You could use Logstash (with GELF input and Elasticsearch output) for that.
