Rotation of active write index
since today, I have problems rotating the active write index.
My setup contains:
  • 3 Nodes
  • 4 Shards
  • 1 Index Set
  • Graylog 2.4.6
  • EL 2.4.5
Here is the output of the logfile:
2018-08-20T14:21:03.413+02:00 INFO  [DeflectorResource] Cycling deflector for index set <592edf5abd2d5662613a0fe7>. Reason: REST request.
2018-08-20T14:21:03.418+02:00 INFO  [MongoIndexSet] Cycling from <graylog_589> to <graylog_590>.
2018-08-20T14:21:03.418+02:00 INFO  [MongoIndexSet] Creating target index <graylog_590>.
2018-08-20T14:21:03.551+02:00 INFO  [Indices] Successfully created index template graylog-internal
2018-08-20T14:21:04.198+02:00 INFO  [MongoIndexSet] Waiting for allocation of index <graylog_590>.
2018-08-20T14:21:04.354+02:00 ERROR [IndexRotationThread] Couldn't point deflector to a new index
org.graylog2.indexer.ElasticsearchException: Couldn't read health status for index graylog_589
    at org.graylog2.indexer.cluster.jest.JestUtils.specificException(JestUtils.java:95) ~[graylog.jar:?]
    at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:57) ~[graylog.jar:?]
    at org.graylog2.indexer.cluster.jest.JestUtils.execute(JestUtils.java:62) ~[graylog.jar:?]
    at org.graylog2.indexer.indices.Indices.waitForStatus(Indices.java:642) ~[graylog.jar:?]
    at org.graylog2.indexer.indices.Indices.waitForRecovery(Indices.java:633) ~[graylog.jar:?]
    at org.graylog2.periodical.IndexRotationThread.checkAndRepair(IndexRotationThread.java:163) ~[graylog.jar:?]
    at org.graylog2.periodical.IndexRotationThread.lambda$doRun$0(IndexRotationThread.java:76) ~[graylog.jar:?]
    at java.lang.Iterable.forEach(Iterable.java:75) [?:1.8.0_181]
    at org.graylog2.periodical.IndexRotationThread.doRun(IndexRotationThread.java:73) [graylog.jar:?]
    at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:1.8.0_181]
    at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308) [?:1.8.0_181]
    at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180) [?:1.8.0_181]
    at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294) [?:1.8.0_181]
    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_181]
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_181]
    at java.lang.Thread.run(Thread.java:748) [?:1.8.0_181]
2018-08-20T14:21:04.367+02:00 WARN  [IndexRotationThread] Deflector is pointing to [graylog_587], not the newest one: [graylog_590]. Re-pointing.
2018-08-20T14:21:13.410+02:00 ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
    at okio.Okio$4.newTimeoutException(Okio.java:230) ~[graylog.jar:?]
    at okio.AsyncTimeout.exit(AsyncTimeout.java:285) ~[graylog.jar:?]
    at okio.AsyncTimeout$2.read(AsyncTimeout.java:241) ~[graylog.jar:?]
    at okio.RealBufferedSource.indexOf(RealBufferedSource.java:345) ~[graylog.jar:?]
    at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:217) ~[graylog.jar:?]
    at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:211) ~[graylog.jar:?]
    at okhttp3.internal.http1.Http1Codec.readResponseHeaders(Http1Codec.java:187) ~[graylog.jar:?]
    at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:88) ~[graylog.jar:?]
    at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:147) ~[graylog.jar:?]
    at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:121) ~[graylog.jar:?]
    at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:125) ~[graylog.jar:?]
    at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:200) ~[graylog.jar:?]
    at okhttp3.RealCall.execute(RealCall.java:77) ~[graylog.jar:?]
    at org.graylog2.rest.resources.cluster.ClusterDeflectorResource.cycle(ClusterDeflectorResource.java:75) ~[graylog.jar:?]
    at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_181]
    at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_181]
    at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_181]
    at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_181]
    at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[graylog.jar:?]
    at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[graylog.jar:?]
    at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[graylog.jar:?]
    at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$VoidOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:143) ~[graylog.jar:?]
    at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[graylog.jar:?]
    at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[graylog.jar:?]
    at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[graylog.jar:?]
    at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[graylog.jar:?]
    at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [graylog.jar:?]
    at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [graylog.jar:?]
    at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [graylog.jar:?]
    at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [graylog.jar:?]
    at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [graylog.jar:?]
    at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [graylog.jar:?]
    at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [graylog.jar:?]
    at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [graylog.jar:?]
    at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [graylog.jar:?]
    at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:384) [graylog.jar:?]
    at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:224) [graylog.jar:?]
Caused by: java.net.SocketException: Socket closed
    at java.net.SocketInputStream.read(SocketInputStream.java:204) ~[?:1.8.0_181]
    at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:1.8.0_181]
    at okio.Okio$2.read(Okio.java:139) ~[graylog.jar:?]
    at okio.AsyncTimeout$2.read(AsyncTimeout.java:237) ~[graylog.jar:?]
    ... 51 more
did you checked the health of your elasticsearch and that it response in time for Graylog?
here is the health:
  "cluster_name" : "graylog",
  "status" : "red",
  "timed_out" : false,
  "number_of_nodes" : 3,
  "number_of_data_nodes" : 3,
  "active_primary_shards" : 1456,
  "active_shards" : 1456,
  "relocating_shards" : 0,
  "initializing_shards" : 0,
  "unassigned_shards" : 12,
  "active_shards_percent_as_number" : 99.1825613079019
How do I find out the response time?
kind regards
Philipp
you should read our short description about the different status messages in the documentation:
http://docs.graylog.org/en/2.4/pages/configuration/elasticsearch.html#cluster-status-explained
As you have unassigned shard != 0 you might want to check with the following articel that you have no unassigned shards and your status is green again.
After the status is green again, your Graylog will be able to rotate the index.
