Hi is there any way of restrict a search query in resource limit. so not u overload the query to ES or in Graylog. som buffer settings or processer settings
You can limit user queries in System - Configurations
- in section Search Configuration
For example you can completely remote “ Search in all messages
” or change it to limit to 30 days for example, changing value from PT0S
to P30D
. Or you can add your own timeranges of you want.
https://docs.graylog.org/en/4.0/pages/searching/configuration.html#query-time-range-limit
yes sorry i was not clear enough but i want to restrict in more the speed of query and limit it in resources not in days/time
like set prio of the query so when someone do a search it will take longer time. this is due to we have one system that get almost 5TB per day of logs… and building a Webui to query with rest api to graylog.
I don’t think so, that it’s possible by graylog.
hmm i guess this will be the option the in ES
batched_reduce_size, this can limit
The number of shard results that should be reduced at once on the coordinating node. This value should be used as a protection mechanism to reduce the memory overhead per search request if the potential number of shards in the request can be large.
