Resolving Kafla problem /var/lib/graylog-server/journal
Hi All, I have the solution fo this problem
Getting this error suddenly without any changes done on graylog server.
2020-03-11T12:30:09.698+05:30 ERROR [KafkaJournal] Unable to start logmanager.
kafka.common.KafkaException: Failed to acquire lock on file .lock in /var/lib/graylog-server/journal. A Kafka instance in another process or thread is using this directory.
at kafka.log.LogManager$$anonfun$lockLogDirs$1.apply(LogManager.scala:98) ~[graylog.jar:?]
at kafka.log.LogManager$$anonfun$lockLogDirs$1.apply(LogManager.scala:95) ~[graylog.jar:?]
at scala.collection.TraversableLike$$anonfun$map$1.apply(TraversableLike.scala:234) ~[graylog.jar:?]
at scala.collection.IndexedSeqOptimized$class.foreach(IndexedSeqOptimized.scala:33) ~[graylog.jar:?]
at scala.collection.mutable.WrappedArray.foreach(WrappedArray.scala:35) ~[graylog.jar:?]
at scala.collection.TraversableLike$class.map(TraversableLike.scala:234) ~[graylog.jar:?]
at scala.collection.AbstractTraversable.map(Traversable.scala:104) ~[graylog.jar:?]
at kafka.log.LogManager.lockLogDirs(LogManager.scala:95) ~[graylog.jar:?]
at kafka.log.LogManager.(LogManager.scala:57) ~[graylog.jar:?]
at org.graylog2.shared.journal.KafkaJournal.(KafkaJournal.java:326) [graylog.jar:?]
at org.graylog2.shared.journal.KafkaJournal.(KafkaJournal.java:191) [graylog.jar:?]
at org.graylog2.shared.journal.KafkaJournal$$FastClassByGuice$$8f50433e.newInstance() [graylog.jar:?]
at com.google.inject.internal.DefaultConstructionProxyFactory$FastClassProxy.newInstance(DefaultConstructionProxyFactory.java:89) [graylog.jar:?]
at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:114) [graylog.jar:?]
at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:91) [graylog.jar:?]
at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:306) [graylog.jar:?]
at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40) [graylog.jar:?]
at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:148) [graylog.jar:?]
at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:39) [graylog.jar:?]
at com.google.inject.internal.FactoryProxy.get(FactoryProxy.java:62) [graylog.jar:?]
at com.google.inject.internal.SingleParameterInjector.inject(SingleParameterInjector.java:42) [graylog.jar:?]
at com.google.inject.internal.SingleParameterInjector.getAll(SingleParameterInjector.java:65) [graylog.jar:?]
at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:113) [graylog.jar:?]
at com.google.inject.internal.InternalInjectorCreator.loadEagerSingletons(InternalInjectorCreator.java:211) [graylog.jar:?]
at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:182) [graylog.jar:?]
at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:109) [graylog.jar:?]
at com.google.inject.Guice.createInjector(Guice.java:87) [graylog.jar:?]
at org.graylog2.shared.bindings.GuiceInjectorHolder.createInjector(GuiceInjectorHolder.java:34) [graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.setupInjector(CmdLineTool.java:379) [graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:194) [graylog.jar:?]
I have tried changing the journal data path but still same issue. Graylog works fine after deleting the journal folder but again after sometime I am getting the above logs.
When you have this problem you can do this!
systemctl stop graylog-server
rm -rf /var/lib/graylog-server/journal
mkdir /var/lib/graylog-server/journal
chown graylog:graylog /var/lib/graylog-server/journal
systemctl restart graylog-server
