Replace Default Index Mapping
I’ve got a simple question, how do I replace the default Index Mapping with a custom one?
In this https://docs.graylog.org/en/3.3/pages/configuration/elasticsearch.html#custom-index-mappings document I don’t really understand how to do it. The type “keyword” doesn’t fit with my needs. I need to change it into “winlogbeat_user_name”.
Thanks for any answers in advance.
Best regards,
beep
Those are two different things you are talking about there. Elasticsearch uses these data types but “winlogbeat_user_name” is a field name applied to a data type of “keyword” which by default sounds correct… Do you want to change the field name? That would be a pipeline rule attached to the stream using the rename_field() function. If it is the data type you want to change that would be going from “keyword” to what?
