Related to : Trouble restring a search to a field value - Daily Challenges - Graylog Community
I started looking at some of the fields I get from my unifi syslog entries running through a pipe line. I get a field called rule_name that I want to be able to search on, and I think to do this I should use a custom_index_mapper.
I’ve put everything from my unifi stream in it’s own index set, I believe it’s called unifi_0.
[root@elasticsearch elasticsearch]# curl -X GET 'http://localhost:9200/_template/unifi_0?pretty'
I think this is the index definition:
[root@elasticsearch elasticsearch]# curl -XGET -u graylog 'http://localhost:9200/unifi_0/?pretty'
Enter host password for user 'graylog':
"unifi_0" : {
"aliases" : {
"unifi_deflector" : { }
"mappings" : {
"dynamic_templates" : [
"internal_fields" : {
"match" : "gl2_*",
"match_mapping_type" : "string",
"mapping" : {
"type" : "keyword"
"store_generic" : {
"mapping" : {
"type" : "keyword"
"properties" : {
"3way_hs" : {
"type" : "keyword"
"MAC_addr" : {
"type" : "keyword"
"dst_addr" : {
"type" : "keyword"
"dst_port" : {
"type" : "keyword"
"facility" : {
"type" : "keyword"
"facility_num" : {
"type" : "long"
"full_message" : {
"type" : "text",
"analyzer" : "standard"
"gl2_accounted_message_size" : {
"type" : "long"
"gl2_message_id" : {
"type" : "keyword"
"gl2_processing_timestamp" : {
"type" : "date",
"format" : "uuuu-MM-dd HH:mm:ss.SSS"
"gl2_receive_timestamp" : {
"type" : "date",
"gl2_remote_ip" : {
"type" : "keyword"
"gl2_remote_port" : {
"type" : "long"
"gl2_source_input" : {
"type" : "keyword"
"gl2_source_node" : {
"type" : "keyword"
"id" : {
"type" : "keyword"
"in_interface" : {
"type" : "keyword"
"length_1" : {
"type" : "keyword"
"length_2" : {
"type" : "keyword"
"level" : {
"type" : "long"
"message" : {
"type" : "text",
"out_interface" : {
"type" : "keyword"
"prec" : {
"type" : "keyword"
"protocol" : {
"type" : "keyword"
"res" : {
"type" : "keyword"
"rule_name" : {
"type" : "keyword"
"source" : {
"type" : "text",
"analyzer" : "analyzer_keyword",
"fielddata" : true
"src_addr" : {
"type" : "keyword"
"src_port" : {
"type" : "keyword"
"streams" : {
"type" : "keyword"
"timestamp" : {
"type" : "date",
"tos" : {
"type" : "keyword"
"ttl" : {
"type" : "keyword"
"urgp" : {
"type" : "keyword"
"window" : {
"type" : "keyword"
"settings" : {
"index" : {
"number_of_shards" : "4",
"provided_name" : "unifi_0",
"creation_date" : "1625101698685",
"analysis" : {
"analyzer" : {
"analyzer_keyword" : {
"filter" : "lowercase",
"tokenizer" : "keyword"
"number_of_replicas" : "0",
"uuid" : "",
"version" : {
"created" : "7100299"
So the field I want to initially index is rule_name
"rule_name" : {
"type" : "keyword"
I’ve got this is the custom mapping:
"template": "unifi_0",
"mappings" : {
"message" : {
"properties" : {
"rule_name" : {
"type" : "string",
"index" : "not_analyzed"
And I’m getting the following when putting:
[root@elasticsearch elasticsearch]# curl -XPUT -d @graylog_unifi_template.json 'http://localhost:9200/_template/unifi_0?pretty' -H 'Content-Type: application/JSON'
"error" : {
"root_cause" : [
"type" : "mapper_parsing_exception",
"reason" : "Root mapping definition has unsupported parameters: [message : {properties={rule_name={index=not_analyzed, type=string}}}]"
"reason" : "Failed to parse mapping [_doc]: Root mapping definition has unsupported parameters: [message : {properties={rule_name={index=not_analyzed, type=string}}}]",
"caused_by" : {
"status" : 400
I’m not sure I understand the message. I based it off this: Elasticsearch — Graylog 3.2.0 documentation and replaced ‘http_method’ with rule_name.
Any guidance appreciated.
