Reimport the default inputs
Hi community,
is there anyway to reimport the default inputs? since I deleted the default inputs, I can receive data just in RAW UDP format. It is too hard create rules from RAW format.
I mean these two local inputs
http://docs.graylog.org/en/2.3/pages/getting_started/check_messages.html
I would be grateful if someone could help me in this matter.
These inputs are part of the content pack which is automatically imported into the Graylog omnibus package.
Check System/Content Packs.
Alternatively you can find the content pack in the Graylog2/omnibus-graylog2 repository on GitHub:
