Help with creating input for log ingestion - Untangle Router
Graylog Server Version - 4.1.7
Hello Forum,
I tried importing these Add-ons into Graylog to help with ingesting log data from my Untangle Security router but both json files failed with messages that the json wasn’t correct. I think these also may be old as my Graylog server is newer at version 4.1.7. How can I check which version of Graylog these add-ons would work?
So I instead found this post here to help me setup an input on Graylog : Graylog with Untangle - #3 by gsmith
For instructions on how to add my Untangle Security Router logs to Graylog. The instructions say to complete the following:
  • On the graylog side make sure you have an input setup for untangle
  • On the input you need to add 2 extractors:
Extractor 1:
  • Select Regex
  • use the following :\s\s+(.*)
  • store field as “json”
  • give it a name
Extractor 2:
  • Select type JSON
  • Keep default values
  • Do not select “flatted values”
My questions are:
What kind of Input do I create? Do I create a UDP input with the following parms:
  • allow_override_date: true
  • bind_address: 0.0.0.0
  • expand_structured_data: false
  • force_rdns: false
  • number_worker_threads: 6
  • override_source:
  • port: 1514
  • recv_buffer_size: 1048576
  • store_full_message: false
Thank you.
Hi greavette
I suggest you see the link below .
