I want to know about “tcp_keepalive” parameter.
If we configure it to true, how often does the keep alive packet send ?
Thank you.
Thank you.
Which parameter are you specifically talking about?
ZThank you.
I refer to “Input” definition.
The tcp_keepalive setting simply sets the SO_KEEPALIVE option on the TCP sockets opened by this input.
The specific details are up to the operating system, for example on Linux you can use sysctl to configure them. See http://www.tldp.org/HOWTO/html_single/TCP-Keepalive-HOWTO/#usingkeepalive for details.
