OSSEC UDP Input works but TCP Input dosen't
Both have the same setting but TCP is not sending data both OSSEC and GreyLog are on same server no firewall.
UDP
bind_address: 0.0.0.0
locale:
port: 12000
recv_buffer_size: 262144
timezone: Etc/UTC
use_full_names: false
TCP
locale:
max_message_size: 2097152
port: 10000
recv_buffer_size: 2097152
tcp_keepalive: false
timezone: Etc/UTC
tls_cert_file:
tls_client_auth: disabled
tls_client_auth_cert_file:
tls_enable: false
tls_key_file:
tls_key_password: ********
use_full_names: true
use_null_delimiter: false
Why TCP input is not working ?
what Version of Graylog are you using? are this settings of Graylog or OSSEC? Your given information isn’t complete that someone who is not you can have a picture what you try.
This are inputs from gray log someone who use greylog at least once would know that
As I can’t see option to upload pic I can only use text. This is on latest version on Greylog
