Questions about MongoDB replica set
Hello Mate,
I am fairly new to graylog but I have to manage to set up. But my issue is creating the MongoDB replicate set and Use a replica set instead of a single host.I have followed tons of documentation but still not manage to have it working. Below are the steps I used in creating the
on server A and B
sudo apt-get install mongodb-server
#mongo
replSet = "rs01"
use graylog
db.createUser(
user: “gray”,
pwd: “ubuntu”,
roles: [ “readWrite”, “dbAdmin” ]
nano /etc/graylog/server/server.conf
mongodb_uri = mongodb://gray:ubuntu@serverA:27017,ServerB:27017/graylog?replicaSet=rs01
Please Help me
You do not need to define replicaSet in the mongodb_uri. Just log in normally.
When setting up a replica set, first set up one node. Then start mongo command prompt in the node and command the other node to join in the replica set by rs.add(“serverB:27017”). The user accounts etc. are automatically added in the second node. After adding the node, you can check the status of the replica set by rs.status()
Thanks @jtkarvo
I manage to figure out how it is done.
on Primary Server.
1 set ur /etc/ hosts set to hosts for all the servers.
2 on the primary set ur replica set and bind it nano /etc/mongodb.conf
bind_ip = hostip
port = 27017
replSet = rs0
3 terminal
#mongo
replSet = "rs0"
rs.initiate()
rs.status()
on the Secondary server
2 on the Secondary Server set ur replica set and bind it nano /etc/mongodb.conf
bind_ip = hostip
port = 27017
replSet = rs0
#service mongodb restart
on server A
mongo (hostip)
rs.add(‘secondary SERVER ip:27017’)
rs0:PRIMARY>
ON SECONDARY
#mongo (hostip)
rs0:SECONDARY>
