Question about log-input
How can I collecotr the below path logs by one input rule?
file1: /app/logs/users/.log
file2: /app/logs/depts/
.log
I try to set the path to “[’/app/logs/*’]” ,but collector does not works,
any way to collector “file1+file2” path by one regular expression?
Which version of Graylog are you on? Which collector are you using? can you post your current collector code (in proper formatting)?
THX,problem is resolved,
Graylog Version:2.4.3
Collector is filebeat
sharing is caring …
others could learn from you, please share your solution!
solutions is that i set the logpath to [‘/app/logs/**’]
