Hi everyone,
i’ve setup my graylog server and I can send the logs from client A to graylog server via filebeat and collect with Sidecar. How can I send for example this logs from client A via filebeat and collect via Sidecar :
/var/log/first/A.log
/var/log/second/A.log
The above 2 A.log are different logs but come from same client A.
I can assign on Collector Admin page only One config to Filebeat collector. Is there any way can I collect above logs ?
If I use * in filebeat config =>
filebeat.inputs:
- input_type: log
paths:
-/var/log/*/A.log
Then I will receive all logs, but I will collect it in different collector.
