Queries to system/metrics API endpoint not working anymore when http proxy configured
Hi everybody,
In the process of enabling log enrichment thought threat intelligence plugin, I had to configure a http proxy in order that our graylog server could reach Internet for populating the tables used by this functionality. We specify this proxy configuration with http_proxy_uri configuration variable in configuration file.
Now, we observe this type of error messages in graylog logs:
2020-10-02T10:51:54.455+02:00 WARN [ProxiedResource] Unable to call http://gl.corp.com:9000/api/system/metrics/multiple on node : timeout
2020-10-02T10:51:54.675+02:00 WARN [OkHttpClientProvider] Unable to connect to proxy:
at okio.Okio$4.newTimeoutException(Okio.java:232) ~[graylog.jar:?]
at okio.AsyncTimeout.exit(AsyncTimeout.java:286) ~[graylog.jar:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:241) ~[graylog.jar:?]
at okio.RealBufferedSource.indexOf(RealBufferedSource.java:358) ~[graylog.jar:?]
at okio.RealBufferedSource.readUtf8LineStrict(RealBufferedSource.java:230) ~[graylog.jar:?]
at okhttp3.internal.http1.Http1ExchangeCodec.readHeaderLine(Http1ExchangeCodec.java:242) ~[graylog.jar:?]
at okhttp3.internal.http1.Http1ExchangeCodec.readResponseHeaders(Http1ExchangeCodec.java:213) ~[graylog.jar:?]
at okhttp3.internal.connection.Exchange.readResponseHeaders(Exchange.java:115) ~[graylog.jar:?]
at okhttp3.internal.http.CallServerInterceptor.intercept(CallServerInterceptor.java:94) ~[graylog.jar:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:142) ~[graylog.jar:?]
at okhttp3.internal.connection.ConnectInterceptor.intercept(ConnectInterceptor.java:43) ~[graylog.jar:?]
at okhttp3.internal.http.RealInterceptorChain.proceed(RealInterceptorChain.java:117) ~[graylog.jar:?]
at okhttp3.internal.cache.CacheInterceptor.intercept(CacheInterceptor.java:94) ~[graylog.jar:?]
at okhttp3.internal.http.RetryAndFollowUpInterceptor.intercept(RetryAndFollowUpInterceptor.java:88) ~[graylog.jar:?]
at org.graylog2.rest.RemoteInterfaceProvider.lambda$get$0(RemoteInterfaceProvider.java:61) ~[graylog.jar:?]
at okhttp3.RealCall.getResponseWithInterceptorChain(RealCall.java:229) ~[graylog.jar:?]
at okhttp3.RealCall.execute(RealCall.java:81) ~[graylog.jar:?]
at retrofit2.OkHttpCall.execute(OkHttpCall.java:190) ~[graylog.jar:?]
at org.graylog2.shared.rest.resources.ProxiedResource.lambda$getForAllNodes$0(ProxiedResource.java:78) ~[graylog.jar:?]
at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_121]
at java.lang.Thread.run(Thread.java:745) [?:1.8.0_121]
Caused by: java.net.SocketException: Socket closed
at java.net.SocketInputStream.read(SocketInputStream.java:204) ~[?:1.8.0_121]
at java.net.SocketInputStream.read(SocketInputStream.java:141) ~[?:1.8.0_121]
at okio.Okio$2.read(Okio.java:140) ~[graylog.jar:?]
at okio.AsyncTimeout$2.read(AsyncTimeout.java:237) ~[graylog.jar:?]
… 29 more
One of the potential consequence is that in/out events counter on header is not working anymore.
Graylog version is 3.3.6 (just upgraded). Simple deployment: One graylog node (using nginx as reverse proxy), several ES servers behind.
Do somebody know why we observe this behavior following this change? Thanks in advance!
Anybody has a clue about how to solve this not expected behavior?
Last try … I suspect a problem in reverse-proxy configuration but never found a working configuration all our required features support.
As expected, the solution was in the documentation. I took time today to review my graylog configuration and found a new parameter that I wasn’t aware before: http_non_proxy_hosts. With this one set with the value of the IP addressed where graylog socket is listening, the queries to graylog API are not proxied and all is working perfectly :slight_smile:
