Process Buffer - Output Buffer Full
virtualization environment: hyper-v
  • Graylog 4 Node Cluster.
  • 1 master 3 Replica
  • 16 cpu - 32 gb ram
Graylog version 3.3.2
my problem;
Process buffer - Output buffer Full
graylog server.conf
also why the load is not evenly distributed
100 K logs coming in a second.
I’m asking for help
Thanks.
@cemk You need to check your Graylog server.log and elasticsearch log file. There might be your elasticsearch having an issue to accepting messages and log files will give you the exact cause of it.
Do you have outgoing messages? Maybe you just need a bigger elastic cluster.
But an @makarands mentioned, check logs first.
After the IO and other performaces of your graylog and elastic servers.
After that, please check the graylog config file’s comments about processor numbers, and ring sizes. You missconfigured it. (This problem not connected)
You also can check the batch_size parameters.
Hi, no problem on elasticsearch side I checked
@makarands @macko003
the problem we are having, Process Buffer - Output Buffer Full
Is increasing the number of graylog nodes the solution?
Is there anything wrong with the settings I sent ?
is_master = false
password_secret = xxxxx
root_password_sha2 = xxxxx
data_dir = /graylog-data
http_bind_address = 0.0.0.0
http_thread_pool_size = 24
elasticsearch_hosts = xxxxx
rotation_strategy = count
elasticsearch_max_number_of_indices = 8
retention_strategy = delete
elasticsearch_shards = 6
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 4000
output_flush_interval = 1
processbuffer_processors = 12
outputbuffer_processors = 12
ring_size = 262144
inputbuffer_ring_size = 262144
inputbuffer_processors = 16
message_journal_dir = /graylog-data/graylog/data/journal
message_journal_max_age = 12h
message_journal_max_size = 40gb
mongodb_uri = xxxxx
Yes, but the buffers fulls because the elastic can’t adsorb as many messages as graylog tries to send.
As I mentioned, check the config file’s comments. You should use less processors in the config what you have. Input, process, and output 's sum should be less then 16. But it is not releated with your problem…
And the ring size should fit in your processors cache.
But it’s just my memory, check the config and the docs.
As I see you decrease the batch size. Check the docs, what it is. Maybe it makes clear everything.
