My Graylog server recently started having issues with the Process and Output buffers being full 100% of the time. I increased the CPU count on the VM and modified the ‘processbuffer_processors’ and ‘outputbuffer_processors’ accordingly to no avail. I know I need to adjust something else, I am not sure what that something else is.
Server Config
RHEL 8.3
Graylog 4.0.5+d95b909, codename Noir
Elasticsearch 6.8.15
Current Hardware
24 CPUs
32 GB Memory
3TB space
Graylog Config
is_master = true
password_secret =
root_password_sha2 =
http_bind_address =
http_bind_address =
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 5000
output_flush_interval = 1
processbuffer_processors = 8
outputbuffer_processors = 4
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 4
message_journal_max_size = 15gb
transport_email_hostname =
transport_email_port = 25
transport_email_from_email =
versionchecks = false
Elasticsearch Config
cluster.name: graylog
path.data: /home/elasticsearch/elasticsearch
path.logs: /home/elasticsearch/log
As you can see, I do not have a complicated setup. If there are any other logs that need to be displayed, just let me know.
If your output buffer and process buffer are both at 100%, then there’s a resourcing issue (likely around heap). Have you tried increasing Graylog’s heap or Elasticsearch’s heap at all?
I have. The Graylog heap is set to 8GB and I just up the Elasticsearch to 8GB. I didn’t realize that it was set to 1GB.
Graylog
# Path to the java executable.
JAVA=/usr/bin/java
GRAYLOG_SERVER_JAVA_OPTS="-Xms8g -Xmx8g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUn$
# Avoid endless loop with some TLSv1.3 implementations.
GRAYLOG_SERVER_JAVA_OPTS="$GRAYLOG_SERVER_JAVA_OPTS -Djdk.tls.acknowledgeCloseNotify=true"
# Pass some extra args to graylog-server. (i.e. "-d" to enable debug mode)
GRAYLOG_SERVER_ARGS=""
# Program that will be used to wrap the graylog-server command. Useful to
# support programs like authbind.
GRAYLOG_COMMAND_WRAPPER=""
Elasticsearch
## JVM configuration
## IMPORTANT: JVM heap size
## You should always set the min and max JVM heap
## size to the same value. For example, to set
## the heap to 4 GB, set:
## -Xms4g
## -Xmx4g
## See https://www.elastic.co/guide/en/elasticsearch/reference/current/heap-size.html
## for more information
# Xms represents the initial size of total heap space
# Xmx represents the maximum size of total heap space
-Xms8g
-Xmx8g
## Expert settings
## All settings below this section are considered
## expert settings. Don't tamper with them unless
## you understand what you are doing
## GC configuration
8-13:-XX:+UseConcMarkSweepGC
8-13:-XX:CMSInitiatingOccupancyFraction=75
8-13:-XX:+UseCMSInitiatingOccupancyOnly
## G1GC Configuration
# NOTE: G1 GC is only supported on JDK version 10 or later
# to use G1GC, uncomment the next two lines and update the version on the
# following three lines to your version of the JDK
# 10-13:-XX:-UseConcMarkSweepGC
# 10-13:-XX:-UseCMSInitiatingOccupancyOnly
14-:-XX:+UseG1GC
14-:-XX:G1ReservePercent=25
14-:-XX:InitiatingHeapOccupancyPercent=30
## DNS cache policy
# cache ttl in seconds for positive DNS lookups noting that this overrides the
# JDK security property networkaddress.cache.ttl; set to -1 to cache forever
-Des.networkaddress.cache.ttl=60
# cache ttl in seconds for negative DNS lookups noting that this overrides the
# JDK security property networkaddress.cache.negative ttl; set to -1 to cache
# forever
-Des.networkaddress.cache.negative.ttl=10
## optimizations
# pre-touch memory pages used by the JVM during initialization
-XX:+AlwaysPreTouch
## basic
# explicitly set the stack size
-Xss1m
# set to headless, just in case
-Djava.awt.headless=true
# ensure UTF-8 encoding by default (e.g. filenames)
-Dfile.encoding=UTF-8
# use our provided JNA always versus the system one
-Djna.nosys=true
# turn off a JDK optimization that throws away stack traces for common
# exceptions because stack traces are important for debugging
-XX:-OmitStackTraceInFastThrow
# enable helpful NullPointerExceptions (https://openjdk.java.net/jeps/358), if
# they are supported
14-:-XX:+ShowCodeDetailsInExceptionMessages
# flags to configure Netty
-Dio.netty.noUnsafe=true
-Dio.netty.noKeySetOptimization=true
-Dio.netty.recycler.maxCapacityPerThread=0
# log4j 2
-Dlog4j.shutdownHookEnabled=false
-Dlog4j2.disable.jmx=true
-Djava.io.tmpdir=${ES_TMPDIR}
## heap dumps
# generate a heap dump when an allocation from the Java heap fails
# heap dumps are created in the working directory of the JVM
-XX:+HeapDumpOnOutOfMemoryError
# specify an alternative path for heap dumps; ensure the directory exists and
# has sufficient space
-XX:HeapDumpPath=/var/lib/elasticsearch
# specify an alternative path for JVM fatal error logs
-XX:ErrorFile=/var/log/elasticsearch/hs_err_pid%p.log
## JDK 8 GC logging
8:-XX:+PrintGCDetails
8:-XX:+PrintGCDateStamps
8:-XX:+PrintTenuringDistribution
8:-XX:+PrintGCApplicationStoppedTime
8:-Xloggc:/var/log/elasticsearch/gc.log
8:-XX:+UseGCLogFileRotation
8:-XX:NumberOfGCLogFiles=32
8:-XX:GCLogFileSize=64m
# JDK 9+ GC logging
9-:-Xlog:gc*,gc+age=trace,safepoint:file=/var/log/elasticsearch/gc.log:utctime,pid,tags:filecount=32,filesize=64m
# due to internationalization enhancements in JDK 9 Elasticsearch need to set the provider to COMPAT otherwise
# time/date parsing will break in an incompatible way for some date patterns and locals
9-:-Djava.locale.providers=COMPAT
# temporary workaround for C2 bug with JDK 10 on hardware with AVX-512
10-:-XX:UseAVX=2
So, both Graylog and Elasticsearch take their settings from the environment variable files found in either /etc/default/{graylog-server,elasticsearch} or /etc/sysconfig/{graylog-server,elasticsearch}, depending on the distro. For Graylog, the file looks like
cat /etc/default/graylog-server
JAVA=/usr/bin/java
GRAYLOG_SERVER_JAVA_OPTS="-Xms1g -Xmx1g -XX:NewRatio=1 -server -XX:+ResizeTLAB -XX:-OmitStackTraceInFastThrow"
You’d change the heap in the GRAYLOG_SERVER_JAVA_OPTS variable.
Not sure why my post is formatted this way. Apologies.
No worries–discourse uses Markdown, so # get interpreted as header levels. Surrounding any configs with ``` will do the trick to keep things from being oddly formatted.
Since both are now using 8GB, are you still seeing a backlog of messages?
Uh-oh…I think in making some of these changes I broke Graylog. Gotta put this convo on pause so I can go see what I broke.
So I broke the server enough to where I had to rebuild. Buffer is not a issue any more.
