Servus @jan
Thanks for your immediate reply. I think you’re right, for some reason the ntp service wasn’t running, and therefore the time didn’t get synced.
However, I have now started the ntpd on all nodes, but it seems mongodb is still in a recovering state.
In the mongo shell it says “recovering”
rs-graylog:RECOVERING>
"2020-02-06T13:12:01.534+0100 I NETWORK [listener] connection accepted from 10.17.7.1:37294 #776 (10 connections now open)",
"2020-02-06T13:12:01.534+0100 I NETWORK [conn776] end connection 10.17.7.1:37294 (9 connections now open)",
"2020-02-06T13:12:29.558+0100 I NETWORK [listener] connection accepted from 10.18.7.1:37498 #777 (10 connections now open)",
"2020-02-06T13:12:29.560+0100 I NETWORK [conn777] end connection 10.18.7.1:37498 (9 connections now open)",
"2020-02-06T13:12:42.821+0100 I REPL [rsBackgroundSync] sync source candidate: server3.blabla.com:27017",
"2020-02-06T13:12:42.822+0100 I REPL [replication-0] We are too stale to use server3.blabla.com:27017 as a sync source. Blacklisting this sync source because our last fetched timestamp: Timestamp(1579543862, 2) is before their earliest timestamp: Timestamp(1580907197, 1889) for 1min until: 2020-02-06T13:13:42.822+0100",
"2020-02-06T13:12:42.822+0100 I REPL [replication-0] sync source candidate: server2.blabla.com:27017",
"2020-02-06T13:12:42.822+0100 I REPL [replication-0] We are too stale to use server2.blabla.com:27017 as a sync source. Blacklisting this sync source because our last fetched timestamp: Timestamp(1579543862, 2) is before their earliest timestamp: Timestamp(1580906717, 975) for 1min until: 2020-02-06T13:13:42.822+0100",
"2020-02-06T13:12:42.822+0100 I REPL [replication-0] could not find member to sync from",
"2020-02-06T13:13:01.528+0100 I NETWORK [listener] connection accepted from 10.17.7.1:57436 #778 (10 connections now open)",
"2020-02-06T13:13:01.528+0100 I NETWORK [conn778] end connection 10.17.7.1:57436 (9 connections now open)",
"2020-02-06T13:13:29.556+0100 I NETWORK [listener] connection accepted from 10.18.7.1:57688 #779 (10 connections now open)",
"2020-02-06T13:13:29.556+0100 I NETWORK [conn779] end connection 10.18.7.1:57688 (9 connections now open)",
"2020-02-06T13:13:42.831+0100 I REPL [rsBackgroundSync] sync source candidate: server3.blabla.com:27017",
"2020-02-06T13:13:42.831+0100 I REPL [replication-0] We are too stale to use server3.blabla.com:27017 as a sync source. Blacklisting this sync source because our last fetched timestamp: Timestamp(1579543862, 2) is before their earliest timestamp: Timestamp(1580907197, 1889) for 1min until: 2020-02-06T13:14:42.831+0100",
"2020-02-06T13:13:42.831+0100 I REPL [replication-0] sync source candidate: server2.blabla.com:27017",
"2020-02-06T13:13:42.832+0100 I REPL [replication-0] We are too stale to use server2.blabla.com:27017 as a sync source. Blacklisting this sync source because our last fetched timestamp: Timestamp(1579543862, 2) is before their earliest timestamp: Timestamp(1580906717, 975) for 1min until: 2020-02-06T13:14:42.832+0100",
"2020-02-06T13:13:42.832+0100 I REPL [replication-0] could not find member to sync from",
"2020-02-06T13:14:01.528+0100 I NETWORK [listener] connection accepted from 10.17.7.1:49416 #780 (10 connections now open)",
"2020-02-06T13:14:01.528+0100 I NETWORK [conn780] end connection 10.17.7.1:49416 (9 connections now open)",
"2020-02-06T13:14:03.631+0100 I NETWORK [LogicalSessionCacheRefresh] Starting new replica set monitor for rs-graylog/server1.blabla.com:27017,server2.blabla.com:27017,server3.blabla.com:27017",
"2020-02-06T13:14:03.634+0100 I NETWORK [LogicalSessionCacheRefresh] Starting new replica set monitor for rs-graylog/server1.blabla.com:27017,server2.blabla.com:27017,server3.blabla.com:27017",
"2020-02-06T13:14:25.404+0100 I NETWORK [listener] connection accepted from 127.0.0.1:51316 #781 (10 connections now open)",
"2020-02-06T13:14:25.405+0100 I NETWORK [conn781] received client metadata from 127.0.0.1:51316 conn781: { application: { name: \"MongoDB Shell\" }, driver: { name: \"MongoDB Internal Client\", version: \"4.0.12\" }, os: { type: \"Linux\", name: \"Red Hat Enterprise Linux Server release 7.7 (Maipo)\", architecture: \"x86_64\", version: \"Kernel 3.10.0-1062.el7.x86_64\" } }",
"2020-02-06T13:14:29.555+0100 I NETWORK [listener] connection accepted from 10.18.7.1:49578 #782 (11 connections now open)",
"2020-02-06T13:14:29.555+0100 I NETWORK [conn782] end connection 10.18.7.1:49578 (10 connections now open)"
"ok" : 1,
"operationTime" : Timestamp(1579543862, 2),
"$clusterTime" : {
"clusterTime" : Timestamp(1580991270, 7),
"signature" : {
"hash" : BinData(0,"AAAAAAAAAAAAAAAAAAAAAAAAAAA="),
"keyId" : NumberLong(0)
Do you think this is a lost caused, or will it eventually finish recovering?
Would the restart of the mongod process help?
Lg,
theresa
