Timestamp in graylog does not match logs being ingested
See title. The logs coming into graylog are off by 4 hours even though everything is configured for America/Detroit.
  • OS Information: Ubuntu 22.04
  • Package Version: Graylog 5.0.7 / Opensearch 2.5 / Mongodb 6.0.6
Graylog/MongoDB server:
timedatectl status
               Local time: Tue 2023-05-16 13:42:48 EDT
           Universal time: Tue 2023-05-16 17:42:48 UTC
                 RTC time: Tue 2023-05-16 17:42:48
                Time zone: America/Detroit (EDT, -0400)
System clock synchronized: yes
              NTP service: active
          RTC in local TZ: no
Opensearch server:
timedatectl status
               Local time: Tue 2023-05-16 13:43:33 EDT
           Universal time: Tue 2023-05-16 17:43:33 UTC
                 RTC time: Tue 2023-05-16 17:43:33
              NTP service: active
          RTC in local TZ: no
Fortigate:
Logs in Graylog dashbaord:
Verified all timed/date configuration. Restarted services and even restarted servers.
Any guidance to get timestamps in graylog web dashboard to match actual log timestamp would be appreciated.
One thing I find interesting is that there is a pre-parsed field in the log that is:
tz = -0400
which equals the time offset between what graylog dashboard is showing and what the actual timestamp is. Is graylog somehow reading that time zone and applying it?
EDT is 4h ahead of UTC, so I think this is just a case of message times showing as UTC.
Here is a good summary of time zone issues:
EDT is 4 hours behind UTC. It seems the issue is with how fortigate sends its logs.
I was able to resolve the issue by modifying the timestamp field with a pipeline rule:
rule "fortigate timestamp"
    has_field("devname") && has_field("date") && has_field("time")
    let part1 = concat(to_string($message.date), " ");
    let part2 = concat(part1, to_string($message.time));
    let shift_timestamp = parse_date(value:to_string(part2), pattern:"yyyy-MM-dd HH:mm:sss", timezone:"America/Detroit");
    set_field("timestamp", shift_timestamp);
