Problems about sorting in the datatable
The problem I meet is that I create an extractor that can get the duration time form the logger. I put them in the datatable and want to sort with duration desc with its timestamp. I found out that the data table show me the result that the duration time ordered in the String form instead of numeric. However, if I sort the duration with duration time only(no timestamp). It works. I wanna if something I got wrong.
windows server 2016 datacenter
Graylog 5.0.6+51f2df8 on d838a8d5dc50 (Eclipse Adoptium 17.0.6 on Linux 3.10.0-1062.4.1.el7.x86_64)
I have tried to use the converter in the extractor but it doesn’t work.
Any idea that can help me to make the duration order preperly with the timestamp.
Hey @Kagari
What happens if you move “duration” above “Timestamp” ?
Hey @gsmith ,
I have tried that before I posted my question here. They have no change except their locations. I attached the screenshot here.
