Problem with recalculate index by curl
When i use graylog interface to recalculate index, i’ve no problem, it’s ok (System/indices/my indice / Maintenance / recalculate index range)
But when i do it by curl, there is no effect…
curl -XPOST hxxp://127.0.0.1:9000/api/system/indices/ranges/rebuild
i try to rebuild specific index after doing curl -XGET http://localhost:9200/_cat/indices and select my index and do
curl -XPOST hxxp://127.0.0.1:9000/api/system/indices/ranges/index_set/graylog_0/rebuild
Have you an idea why ? For my project, i need to recalculate it by curl, so i search an issue.
Regards
you need to make this request authenticated as administrator. … if that is not working, check the Graylog server.log.
Thanks a lot, it’s work with a admin user
