I have some problems with message count widget. In the example below, I should have some bars but I have nothing. If I zoom in, bars appear.
What am I doing wrong ?
Edit: I’m using Graylog 3.2.2+2f9a628
This looks like a bug. Can you have a look into your server log, and web dev console for any errors, when displaying this?
Thanks a lot!
Usually in this case I use ctrl+f5.
Somehow the histogram don’t update the search’s result well.
I just came back to this. I know what the problem is:
Sorry it only came now to my mind.
- Konrad
