(all docker containers)
Server1: Graylog 6.2
Server2: Mongodb 7.x and Datanode 6.2
Delete Mongodb database since this was a previous Graylog install.
Started Datanode on Server2:
docker run -d … -e GRAYLOG_DATANODE_NODE_NAME=“server2.ourdomain.com” …
which should set the domain name of the data node instance, but it doesn’t seem to take effect because when I go through the pre-flight on Server1 Graylog web interface it’s showing me the Docker “container ID” of DataNode on Server2, and not the domain name. Then it wants to create a certificate based on the container ID and make connectivity using that name – which obviously fails since Server1 and Server2 are physically distinct servers. What am I missing?
OS Information:
Docker -
Package Version:
environment variables set via docker run command
Changed the order of the environment variables in the docker run command.
Why is the docker container ID showing in the image above?
