kovalroma
(Kovalroma)
February 18, 2019, 12:48pm
1
Hello, this topic somehow related to this issue Possible bracketless IPv6 literal Graylog 3.0
What I am trying to do is just to start Graylog from docker-compose using manual
Here is docker compose directly copy-paste from manual (changed my server local IP address only)
version: '2'
services:
mongodb:
image: mongo:3
volumes:
- mongo_data:/data/db
# Elasticsearch: https://www.elastic.co/guide/en/elasticsearch/reference/5.6/docker.html
elasticsearch:
image: docker.elastic.co/elasticsearch/elasticsearch-oss:6.5.4
volumes:
environment:
- http.host=0.0.0.0
- transport.host=localhost
- network.host=0.0.0.0
ulimits:
memlock:
soft: -1
hard: -1
mem_limit: 1g
graylog:
image: graylog/graylog:3.0
volumes:
environment:
- GRAYLOG_PASSWORD_SECRET=somepasswordpepper
# Password: admin
- GRAYLOG_ROOT_PASSWORD_SHA2=8c6976e5b5410415bde908bd4dee15dfb167a9c873fc4bb8a81f6f2ab448a918
- GRAYLOG_HTTP_BIND_ADDRESS=http://192.168.19.27:9000/api
links:
- mongodb:mongo
- elasticsearch
depends_on:
- mongodb
- elasticsearch
ports:
- 9000:9000
# Syslog TCP
- 514:514
# Syslog UDP
- 514:514/udp
# GELF TCP
- 12201:12201
# GELF UDP
- 12201:12201/udp
# Volumes for persisting data, see https://docs.docker.com/engine/admin/volumes/volumes/
volumes:
mongo_data:
driver: local
es_data:
driver: local
graylog_journal:
driver: local
And this is my error
graylog_1 | 2019-02-18 12:07:33,064 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: AWS plugins 3.0.0 [org.graylog.aws.AWSPlugin]
graylog_1 | 2019-02-18 12:07:33,079 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Collector 3.0.0 [org.graylog.plugins.collector.CollectorPlugin]
graylog_1 | 2019-02-18 12:07:33,086 INFO : org.graylog2.bootstrap.CmdLineTool - Loaded plugin: Threat Intelligence Plugin 3.0.0 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
graylog_1 | 2019-02-18 12:07:33,282 ERROR: org.graylog2.bootstrap.CmdLineTool - Invalid configuration
graylog_1 | com.github.joschi.jadconfig.ValidationException: java.lang.IllegalArgumentException: Possible bracketless IPv6 literal: http://192.168.19.27:9000/api
graylog_1 | at org.graylog2.configuration.HttpConfiguration.validateHttpBindAddress(HttpConfiguration.java:227) ~[graylog.jar:?]
graylog_1 | at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_181]
graylog_1 | at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_181]
graylog_1 | at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_181]
graylog_1 | at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_181]
graylog_1 | at com.github.joschi.jadconfig.ReflectionUtils.invokeMethodsWithAnnotation(ReflectionUtils.java:53) ~[graylog.jar:?]
graylog_1 | at com.github.joschi.jadconfig.JadConfig.invokeValidatorMethods(JadConfig.java:221) ~[graylog.jar:?]
graylog_1 | at com.github.joschi.jadconfig.JadConfig.process(JadConfig.java:100) ~[graylog.jar:?]
graylog_1 | at org.graylog2.bootstrap.CmdLineTool.processConfiguration(CmdLineTool.java:351) [graylog.jar:?]
graylog_1 | at org.graylog2.bootstrap.CmdLineTool.readConfiguration(CmdLineTool.java:344) [graylog.jar:?]
graylog_1 | at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:178) [graylog.jar:?]
graylog_1 | at org.graylog2.bootstrap.Main.main(Main.java:50) [graylog.jar:?]
graylog_1 | Caused by: java.lang.IllegalArgumentException: Possible bracketless IPv6 literal: http://192.168.19.27:9000/api
graylog_1 | at com.google.common.base.Preconditions.checkArgument(Preconditions.java:216) ~[graylog.jar:?]
graylog_1 | at com.google.common.net.HostAndPort.requireBracketsForIPv6(HostAndPort.java:275) ~[graylog.jar:?]
graylog_1 | at org.graylog2.configuration.HttpConfiguration.getHttpBindAddress(HttpConfiguration.java:88) ~[graylog.jar:?]
graylog_1 | at org.graylog2.configuration.HttpConfiguration.validateHttpBindAddress(HttpConfiguration.java:222) ~[graylog.jar:?]
graylog_1 | ... 11 more
graylog-docker-compose_graylog_1 exited with code 1
Any ideas how to fix this ?
jan
(Jan Doberstein)
February 18, 2019, 3:14pm
2
http://docs.graylog.org/en/3.0/pages/configuration/server.conf.html#web-rest-api
http_bind_address = 127.0.0.1:9000
The network interface used by the Graylog HTTP interface.
This network interface must be accessible by all Graylog nodes in the cluster and by all clients using the Graylog web interface.
If the port is omitted, Graylog will use port 9000 by default.
no protocol included - only the ip/port
kovalroma
(Kovalroma)
February 18, 2019, 3:39pm
4
Yes, it helps. Thank you.
There is a mistake
How can we fixed it?
jan
(Jan Doberstein)
February 18, 2019, 3:55pm
6
first it was not clear that the error you mentioned is in the docs.
that is now fixed.
kovalroma
(Kovalroma)
February 18, 2019, 3:57pm
7
Other problem was founded.
graylog-docker-compose_graylog_1 exited with code 255
Full docker-compose output log is here
docker-compose file the same as in the previous post.
jan
(Jan Doberstein)
February 18, 2019, 4:20pm
8
I just copy&pasted the docker-compose from the docs and got a working setup.
kovalroma
(Kovalroma)
February 18, 2019, 7:26pm
9
@jan Can you show me your docker-compose file?
kovalroma
(Kovalroma)
February 18, 2019, 7:41pm
10
My docker-compose:
version: '2'
services:
mongodb:
image: mongo:3
volumes:
elasticsearch:
volumes:
environment:
- http.host=0.0.0.0
ulimits:
memlock:
soft: -1
hard: -1
mem_limit: 1g
graylog:
volumes:
environment:
# Password: admin
- GRAYLOG_HTTP_BIND_ADDRESS=192.168.19.27:9000
links:
- mongodb:mongo
- elasticsearch
depends_on:
- mongodb
- elasticsearch
ports:
- 9000:9000
# Syslog TCP
- 514:514
# Syslog UDP
- 514:514/udp
# GELF TCP
- 12201:12201
# GELF UDP
- 12201:12201/udp
volumes:
mongo_data:
driver: local
es_data:
driver: local
graylog_journal:
driver: local
I changed only GRAYLOG_HTTP_BIND_ADDRESS to my local server IP.
Docker-compose from official docs, Persisting data headline.
And it doesn’t work for me.
Where is my mistake ?
jan
(Jan Doberstein)
February 18, 2019, 7:58pm
11
GRAYLOG_HTTP_BIND_ADDRESS is actually your problem.
How should Graylog bind to the IP that is on the HOST that Docker runs and not the IP of your Docker Container …
kovalroma
(Kovalroma)
February 18, 2019, 8:55pm
12
Ok, I took exactly what is in doc,
version: '2'
services:
mongodb:
image: mongo:3
volumes:
elasticsearch:
volumes:
environment:
- http.host=0.0.0.0
ulimits:
memlock:
soft: -1
hard: -1
mem_limit: 1g
graylog:
volumes:
environment:
# Password: admin
- GRAYLOG_HTTP_BIND_ADDRESS=127.0.0.1:9000
links:
- mongodb:mongo
- elasticsearch
depends_on:
- mongodb
- elasticsearch
ports:
- 9000:9000
# Syslog TCP
- 514:514
# Syslog UDP
- 514:514/udp
# GELF TCP
- 12201:12201
# GELF UDP
- 12201:12201/udp
volumes:
mongo_data:
driver: local
es_data:
driver: local
graylog_journal:
driver: local
graylog/graylog:3.0 - Up 6 minutes (unhealthy)
Can you show me your docker-compose which is launch properly ?
jan
(Jan Doberstein)
February 19, 2019, 8:40am
13
I have the following docker-compose taken from the docs, modified that I can access the UI on my computer
version: '2'
services:
mongodb:
image: mongo:3
elasticsearch:
image: docker.elastic.co/elasticsearch/elasticsearch-oss:6.6.0
environment:
- http.host=0.0.0.0
ulimits:
memlock:
soft: -1
hard: -1
mem_limit: 1g
graylog:
environment:
# CHANGE ME!
# Password: admin
- GRAYLOG_HTTP_BIND_ADDRESS=0.0.0.0:9000
- GRAYLOG_HTTP_EXTERNAL_URI=http://127.0.0.1:9000/
links:
- mongodb:mongo
- elasticsearch
depends_on:
- mongodb
- elasticsearch
ports:
- 9000:9000
# Syslog TCP
- 514:514
# Syslog UDP
- 514:514/udp
# GELF TCP
- 12201:12201
# GELF UDP
- 12201:12201/udp
kovalroma
(Kovalroma)
February 19, 2019, 10:36am
14
Ok, I found misunderstanding.
You use this variable GRAYLOG_HTTP_EXTERNAL_URI=http://127.0.0.1:9000/ , but I didn’t. That’s why my GrayLog works only from local IP, but not from remote.
My proposition is to add GRAYLOG_HTTP_EXTERNAL_URI=http://127.0.0.1:9000/ to the main doc http://docs.graylog.org/en/latest/pages/installation/docker.html for those who want to try GrayLog remotely.
Thank you for your support!
jan
(Jan Doberstein)
February 19, 2019, 11:04am
15
feel free to create a PR for the documentation that highlights this. The Documentation is open source as the product itself.
system
(system)
Closed
March 5, 2019, 11:17am
16
