Pipeline to stream
Don’t work pipeline rules
  • OS Information:
  • Package Version: graylog-server 7.1.3, graylog-datanode 7.1.3
    Message processor
    # Processor Status
    1 AWS Instance Name Lookup active
    2 Pipeline Processor active
    3 Stream Rule Processor active
    4 Message Filter Chain active
    5 GeoIP Resolver active
Hi community, i already have been installed greylog 5 + opensearch, and there was a worked chain - pipeline rules+pipelines and also was worked chain of processor message
thats ok
and about a week ago i make decision an upgrade this by deleting opensearch and graylog and install graylog-server + graylog-datanode 7.1.3 instead olders version.
I restored all my configs (from screenshots thats i made before deleting old ones) - and all works fine unlike pipeline rules
if i trying simulate working pipelines via Simulator - i see a new fields, but in production - nothing happened
Hello @icsj2007,
Good to see you update to the newest release.
Below is the default process order, I would recommend that you use this unless there is some specific reason it was altered. In the current order, pipelines play out before routing to streams.
big thx, ill try it today
but also i want to know - is there any possible way to log message processor ?
big thx to @Wine_Merchant
its really help) even if it was by default)
