we are running Graylog 3.3.5. (rpm installation on redhat 7)
When trying to use the Pipeline Simulator we are getting the following error: “Cannot read property ‘took_microseconds’ of undefined”.
The graylog-server log shows the following:
2020-09-01T10:13:05.750+02:00 ERROR [AnyExceptionClassMapper] Unhandled exception in REST resource
java.lang.NullPointerException: null
at org.graylog.plugins.pipelineprocessor.ast.expressions.ComparisonExpression.evaluateBool(ComparisonExpression.java:54) ~[graylog.jar:?]
at org.graylog.plugins.pipelineprocessor.processors.PipelineInterpreter.evaluateRuleCondition(PipelineInterpreter.java:407) ~[graylog.jar:?]
at org.graylog.plugins.pipelineprocessor.processors.PipelineInterpreter.evaluateStage(PipelineInterpreter.java:303) ~[graylog.jar:?]
at org.graylog.plugins.pipelineprocessor.processors.PipelineInterpreter.processForResolvedPipelines(PipelineInterpreter.java:267) ~[graylog.jar:?]
at org.graylog.plugins.pipelineprocessor.processors.PipelineInterpreter.process(PipelineInterpreter.java:147) ~[graylog.jar:?]
at org.graylog.plugins.pipelineprocessor.rest.SimulatorResource.simulate(SimulatorResource.java:85) ~[graylog.jar:?]
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_262]
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_262]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_262]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_262]
at org.glassfish.jersey.server.model.internal.ResourceMethodInvocationHandlerFactory$1.invoke(ResourceMethodInvocationHandlerFactory.java:81) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher$1.run(AbstractJavaResourceMethodDispatcher.java:144) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.invoke(AbstractJavaResourceMethodDispatcher.java:161) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.JavaResourceMethodDispatcherProvider$TypeOutInvoker.doDispatch(JavaResourceMethodDispatcherProvider.java:205) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.internal.AbstractJavaResourceMethodDispatcher.dispatch(AbstractJavaResourceMethodDispatcher.java:99) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.invoke(ResourceMethodInvoker.java:389) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:347) ~[graylog.jar:?]
at org.glassfish.jersey.server.model.ResourceMethodInvoker.apply(ResourceMethodInvoker.java:102) ~[graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:326) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [graylog.jar:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [graylog.jar:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [graylog.jar:?]
at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:384) [graylog.jar:?]
at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:224) [graylog.jar:?]
at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:181) [graylog.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_262]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_262]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_262]
Any ideas on that?
Thanks for your help.
regards
-Rainer
