in new setup test environment with two server, building an Graylog (3.0.1) and also an ES Cluster (6.5.4) I get always the same error.
I go to Systems->Pipelines and choos the one and only pipelin (which is not yet connectoed to a stream). I click on “Edit Connections” and choose a stream. Immediately i get the “monkey” error page.
Stack Trace:
TypeError: Das Objekt unterstützt diese Aktion nicht.
at clearValue (http://node1:9000/assets/LoadingPage~LoggedInPage~LoginPage.dac1b68c62ef0b247bef.js:1:216287)
at value (http://node1:9000/assets/LoadingPage~LoggedInPage~LoginPage.dac1b68c62ef0b247bef.js:1:140632)
at Eb (http://10.150.159.19:9000/assets/vendor.4024e2a8db732781a971.js:18:48296)
at zt (http://10.150.159.19:9000/assets/vendor.4024e2a8db732781a971.js:18:58297)
at it (http://10.150.159.19:9000/assets/vendor.4024e2a8db732781a971.js:18:63033)
at Vt (http://10.150.159.19:9000/assets/vendor.4024e2a8db732781a971.js:18:78123)
at Ut (http://10.150.159.19:9000/assets/vendor.4024e2a8db732781a971.js:18:78503)
at Tn (http://10.150.159.19:9000/assets/vendor.4024e2a8db732781a971.js:18:84899)
at gn (http://10.150.159.19:9000/assets/vendor.4024e2a8db732781a971.js:18:84286)
at En (http://10.150.159.19:9000/assets/vendor.4024e2a8db732781a971.js:18:90476)
Component Stack:
in i
in div
in p
in fieldset
in div
in div
in p
in form
in div
in div
in div
in p
in Transition
in p
in p
in div
in Portal
in f
in u
in i
in i
in span
in PipelineConnectionsForm
in div
in div
in p
in div
in p
in div
in Pipeline
in div
in p
in div
in p
in div
in i
in PipelineDetailsPage
in n
in div
in p
in div
in p
in div
in t
in div
in t
in n
in withRouter(n)
in div
in App
in RouterContext
in Router
in Unknown
in t
in n
in AppFacade
Can you point to my error? What’s going wrong here?
In the Graylog Log i could not find a hint.
The linux underneath is SLES12SP3
Thanks in advance,
Dietmar
