Dear community,
I am using Graylog 6.3.2 (docker) to gather all sorts of log data in my homelab.
I have recently switched my Unifi USG-3P for a UCG-Ultra. My old pipeline rules need some love to work again.
Unifi sends all sorts of different logs to a stream. I would like to set up several pipeline rules to parse the messages into fields and then forward the messages to different streams with different retention times.
example 1
UCG-Ultra [DMZ_LOCAL-D-2147483647] DESCR="[DMZ_LOCAL]Block All Traffic" IN=br40 OUT= MAC=45:00:00:20:ff:8a:40:00:40:11:52:99:c0:a8 SRC=192.168.40.1 DST=255.255.255.255 LEN=32 TOS=00 PREC=0x00 TTL=64 ID=65418 DF PROTO=UDP SPT=44828 DPT=10001 LEN=12 MARK=1a0000
example 2
UCG-Ultra [VPN_CUSTOM2-A-10000] DESCR="VPN to unsecure (Allow All)" IN=tlprt1 OUT=br30 MAC= SRC=192.168.2.2 DST=192.168.30.20 LEN=60 TOS=00 PREC=0x00 TTL=63 ID=35249 DF PROTO=TCP SPT=48712 DPT=8123 SEQ=885508839 ACK=0 WINDOW=65535 SYN URGP=0 MARK=1a0000
example 3
Aug 30 16:15:02 UCG-Ultra CEF:0|Ubiquiti|UniFi Network|9.3.45|401|WiFi Client Disconnected|2|UNIFIcategory=Monitoring UNIFIsubCategory=WiFi UNIFIhost=UCG Ultra UNIFIlastConnectedToDeviceName=UAP-AC-LR UNIFIlastConnectedToDeviceIp=192.168.1.3 UNIFIlastConnectedToDeviceMac=f0:9f:c2:fc:55:e7 UNIFIlastConnectedToDeviceModel=UAP-AC-LR UNIFIlastConnectedToDeviceVersion=6.6.77 UNIFIclientAlias=Android Device 88:a3 UNIFIclientIp=192.168.20.249 UNIFIclientMac=3a:fb:b9:5d:88:a3 UNIFIwifiChannel=6 UNIFIwifiChannelWidth=20 UNIFIwifiName=csesnsas_mobile UNIFIwifiBand=ng UNIFIwifiAirtimeUtilization=14 UNIFIwifiInterference=1 UNIFIlastConnectedToWiFiRssi=-76 UNIFIduration=39m 34s UNIFIusageDown=520.73 MB UNIFIusageUp=19.90 MB UNIFInetworkName=MobileDevices UNIFInetworkSubnet=192.168.20.0/24 UNIFInetworkVlan=20 msg=Android Device 88:a3 disconnected from csesnsas_mobile. Time Connected: 39m 34s. Data Used: 19.90 MB (up) / 520.73 MB (down). Last Connected To: UAP-AC-LR at -76 dBm.
I was planing to set up several pipeline rules in multiple stages to handle different types of log messages. Each rule should only be applied to messages that have not yet been parsed by stages before. (I have set an additional field “parsed” = “true”.)
Working pipeline rule:
rule "Unifi UCG-Ultra: parsing firewall messages"
grok(
pattern: "^%{DATA:device_name} \\[%{DATA:firewall_rule}\\] DESCR=\"%{DATA:rule_description}\" IN=%{DATA:interface_in} OUT=%{DATA:interface_out} MAC=%{GREEDYDATA:mac} SRC=%{IP:source_ip} DST=%{IP:destination_ip} %{GREEDYDATA:type_of_service} PROTO=%{WORD:network_transport}(?: (?:SPT=%{NUMBER:source_port}|DPT=%{NUMBER:destination_port}|%{GREEDYDATA:other}))*",
value: to_string( $message.message )
).matches == true
set_fields(
grok(
only_named_captures: true
set_field("parsed", "true");
Why does this rule not work with when grok_exists()?
grok_exists(
set_fields(
grok(
(I did not yet include the condition for the not has_field(“parsed”)…)
The Grok-pattern is the same and as far as I understand the Rules quick reference, this should work as well.
Any recomendations to make these rules more efficient is very much welcome.
